brain doesn't read air conditioner
08.07.2021 20:59 # 1
oates55
Hello, the air conditioner is working (there is gas blowing, but there is no cooling), but the air conditioner does not turn on because the brain does not read. Can the brain problem be fixed or can I add a button to activate the air conditioner, thanks
09.07.2021 08:01 # 2
whisky
In a 307 I used years ago, there was a button under the steering wheel like this, going to the brain for air conditioning. later, when there was another malfunction related to the brain, I gave it to the repair. what you say can be done.
09.07.2021 14:52 # 3
oates55
Thank you button. It works fine for now
01.06.2023 13:06 # 4
oates55
My problem persists. I installed an on/off switch, and it works perfectly. However, I think the air conditioner's directional buttons aren't working properly because it doesn't work automatically. I want to remove the on/off switch and throw it away. However, I'm curious about how the air conditioner will be activated and how the directional buttons connected to it will work. The brain is sending commands, but without the on/off switch, the air conditioner won't work. oates552023-06-01 13:15:57
