Brain confused by Peugeot 307 fog light
16.03.2022 15:08 # 1
Ferhatdincer
Hello friends, when there was no problem in the car, my hand did not stop, there are arrow signs under the part where we turned the headlights on the signal arm, I played with it, I did two up and down, the fog light turned on, I think, then I turned it off in the same way, I turned it on again, I checked the car, no extra lamp was on, I wanted to turn it off again, but the airbag warning lamp came on. I stopped it didn't work again, it didn't start, we thought the battery ran out, we thought another battery worked at first, then it was the same again.
16.03.2022 15:45 # 2
Hello teacher. It's actually not a situation that will cause a problem if you play with it primarily. I wonder how many models of your car are without make-up cases, the fog light is not separate, it is inside the headlight. It might have been a coincidence. or if the previous owner had another action taken and canceled and the cables were left exposed, it may have caused a short circuit. There is mas peugeot in Ankara ivedik, they are good at electrical and electronics, especially they know 106-206 and 307 vehicles well.
16.03.2022 15:50 # 3
Ferhatdincer
Thank you for your attention, there are sounds coming from somewhere under the steering wheel, as if something is trying to happen, forcing it.
16.03.2022 16:02 # 4
Please, if the sounds come when you turn the ignition on for the first time without starting the vehicle and go away after a few seconds, if it's normal or if it comes on all the time, then there is a problem.
16.03.2022 16:39 # 5
Ferhatdincer
Thank you very much, when I turn on the ignition, it comes before starting and all the lights are on, it doesn't start, it's a very bad situation
