bow cutting
08.05.2020 18:11 # 1
tsgenc
Hi guys first. my vehicle is 106 xs. about 3 months ago I bought a 5cm sports bow from eibach. The car was not pressed as much as I wanted, but for now I said stay and passed. and about 2 weeks ago I switched from 175/65/14 tires to 195/45/15 tires and bought a cc wheel. Now the height of the car from the ground started to sink with the rims. I decided that it would be more logical to cut the original instead of cutting a sports bow. but I wanted to ask you because I don't know how many pods I cut from the original bow. If my brothers and sisters who have cut the original publication have 106 brothers and sisters, I would be very happy if they could write how many pods they cut and how. thanks.
08.05.2020 18:11 # 2
My brother. I do not think anyone will give information about this subject. We all know that it poses serious dangers. As a result, those springs come out with certain engineers' work, and it means that you ignore all calculations made by cutting it. If the 5 cm eibach did not satisfy you, the air suspension will only satisfy you. It is a bit costly process.
08.05.2020 18:11 # 3
samet206
There is no strange understanding of cutting a bow.
08.05.2020 18:11 # 4
dRhkn
If I were, I would have taken 1 pod from 5 cm bow, I wouldn't touch it any more. How many fingers are sniffing between the ten wheels and the fenders?
08.05.2020 18:11 # 5
Burak
I am not a fan of the original broadcast cease, do you have a solution, unfortunately, I do not follow the subject like you :)
08.05.2020 18:11 # 6
kursat3006
It was done without lowering the bow by lowering the table without cutting the bow, but I couldn't find the person to do it. If you scan my topics, there is a detailed excerpt about the plateau.
08.05.2020 18:11 # 7
ahmed206
God bless
08.05.2020 18:11 # 8
[QUOTE = kursat3006] I have done an operation without cutting the bow without cutting the spring without cutting the bow, but I couldn't find the person to do it. If you scan my topics, there is a detailed excerpt about the plateau. [/ QUOTE]
Exactly Kürsat. When the shock absorber drops down 1 or 2 cm, there is no problem in comfort. If I get good information, I will get it done.
08.05.2020 18:11 # 9
herry
cutting or bowing and pressing them in the fire are very dangerous operations, you may not be thinking of yourself, but it can cost others' lives. I think that 5 cm of spring will fall down to 106 I think a good research will either fall 3.5 or over time. but don't cut it.
08.05.2020 18:11 # 10
kuscu38
book a cold press original pedestrian !!!
08.05.2020 18:11 # 11
FTH
the bow does not cut, even if the bow is cut 3 5 months later, the bow breaks, I experienced the same event on my own 106 teams
08.05.2020 18:11 # 12
[QUOTE = kuscu38] book a cold press original pedestrian !!! [/ QUOTE]
They do it in cold press, bro. Coming to Sagittarius money, they descended to me from 200 to 180.
08.05.2020 18:11 # 13
tsgenc
how can we not get gasoline air: D springs 5cm box is still sure i am sure that there is no chance to be 3.5 cm. I'm not exactly sure between the tire and the fender, but 2 fingers get in. The car is still high, although it avoids the flattened front. I'm afraid to step back
08.05.2020 18:11 # 14
I was just thinking of him. Not if you leave the back as it is because Master 106 has no bow in the back. You have to reduce the torsions :) It's easy.
08.05.2020 18:11 # 15
tsgenc
I am aware that it is an easy process. We have lowered the broadway and kangoo torsion in the street before, but I did not understand how to lower the front of the car from my torsion. I already know that the back of the car is high due to torsion. front lip is where I want it to get closer to the ground. my dropping the torsion lifts more of the car
08.05.2020 18:11 # 16
tsgenc
then we'll see the back torsions and see. Let me print in blank memory on Saturday. We'll look at the situation now. many thanks for your help and ideas
08.05.2020 18:11 # 17
okan4037
Master, do not cut the original springs, the comfort of the car is disrupted and the yawning center of the car changes. sports broadcast distances are probably equal mine. cut them with 3 fingers, you will not lose any comfort, only because the shock absorber has some pressure, it hardens and you will not experience any problems. don't tell me that playing with a table is very risky, as your friends say, you understand what I said if the work is broken on the way
08.05.2020 18:11 # 18
okan4037
friends if you cut the original bow after 1 year, trapezoid shape changes. Do not enter the hot press event, there is a possibility of breakage. they say good to cold press
08.05.2020 18:11 # 19
There's a lot of cold presses around me, no problem at all. There was someone in my adaptation that I know of. I have never heard of trouble with cold press.
08.05.2020 18:11 # 20
herry
If you say that I will be trading, I will be the buyer of the original spring. nevertheless, my advice is that there is a spring suitable for your lowness, research the market, I say cutting and doing business. Thumbs Up
