BOTH SOUND PROBLEM FROM 307 ENGINES |
| 08.05.2020 18:55 | # 1 |
| 08.05.2020 18:55 | # 2 |
THICK a trill SOUND LIKE the ACC in walking through the TRACTION MOTOR VS NO PROBLEM NO in ROLANTİDE A PROBLEM NO ENGINE THAT SOUND removing the ACABA CARTER does not TITERING may be BECAUSE UNDER THE PROTECTION OF STORAGE In FRACTURE THE MASTERS I DID SAY BUT YET CHANGES DO NOT have WEEKEND leaving I will look in vain spend money I SAY
| 08.05.2020 18:55 | # 3 |
tolga.onal |
If it makes a sound when turning the steering wheel full turn and leaving the clutch a little bit, it may be from the crankcase casing, I had 2 screws dropped, it made a sound like you described. you can determine if it is from it
| 08.05.2020 18:55 | # 4 |
where could it milk? or is it pulsating? They screwed to keep the service to the right and left but there is sound again, I gave a sound order that was very frustrating in the car.
