BOTH SOUND FROM 307 ENGINES
08.05.2020 20:11 # 1
masterop
Hello friends, my car is 2005 model 307 1.6 hdi. The sound of blasting from the engine that started after driving the vehicle for a long time started to come as soon as the engine warmed up for the last 2 days. When I checked the oil of my car, the oil level had dropped by half. For this reason, does the car make sound? Today I showed the vehicle to the master, he said that we should remove the engine from the V-belt or timing belt and look at it. As far as I know, there is no sound from the timing. It was also about 40,000 KM after changing the triger. I am waiting for your opinions on the subject.
Engine sound link:
08.05.2020 20:11 # 2
pepecura
the file is downloading but I could not listen to the sound, not the sound file :(
08.05.2020 20:11 # 3
BLACK LION
Check the tension of the belts. It can expand from cold heat. It can be cut or reduced when slightly tightened.
08.05.2020 20:11 # 4
Peugeot35
I think it will most likely be a sound from the back bearing or V-belt. Peugeot35 2017-02-15 14:48:34
08.05.2020 20:11 # 5
ggitaristt
Friend, I could only hear the sound of your engine + your breath + a bit of clicks .. Which one do you complain about?
08.05.2020 20:11 # 6
Oktkor
[QUOTE = ggitaristt] Friend I could only hear the sound of the motor + your breath + a little clicked .. Which one do you complain about?
From your own voice. Should antibiotics begin?
