boite de vit defalant
08.05.2020 19:43 # 1
ramazaneminaksu
Hello friends.
On my Peugeot 307 1.6 petrol / lipg car, I occasionally get a vit derollant error in the boite. As soon as this error occurs, gear changes in the vehicle change, gas feeding is delayed, and the ability to use triptronic disappears. The warning disappears when I restart the vehicle after waiting for a while. Is the reason for this solenoid? If you have encountered such a mistake before, I would be glad if you share your experience.
08.05.2020 19:43 # 2
crazysado
First of all, the language of the error message that you wrote in the settings of your computer is set to English.
08.05.2020 19:43 # 3
ramazaneminaksu
Unfortunately there is no English language option in the car or I couldn't see it. After the error disappears, is it clear if I connect it to the PC anyway?
08.05.2020 19:43 # 4
crazysado
I don't know him exactly, but if you connect it when the malfunction light is on
I think it would be clearer
And which country in the subject of the warning text belongs to which country ?????
08.05.2020 19:43 # 5
ramazaneminaksu
French
08.05.2020 19:43 # 6
talip206
The typical automatic gear fault malfunction you mentioned. The gear protects itself and improves when the ignition is turned off and on. There are English language options, if you do English, we can provide more healthy information. But it's likely a transmission transmission.
08.05.2020 19:43 # 7
ramazaneminaksu
I translated the language into English, and if it gives me error again, I will write it here.
08.05.2020 19:43 # 8
ramazaneminaksu
I translated the language into English, the error is gearnox faulty.
08.05.2020 19:43 # 9
ramazaneminaksu
Gearbox faulty
08.05.2020 19:43 # 10
ramazaneminaksu
Doesn't this error :( gearbox faulty
08.05.2020 19:43 # 11
talip206
Classic automatic transmission malfunction. It is solved by 80 percent solenoid change. 20 percent may have different problems. It is necessary to go to the gearbox and connect to the device. The exact solution then becomes clear.
