Bluetooth password hk.
08.05.2020 16:52 # 1
datelk
How can I find my vehicle & nbsp; bluetooth password? Thanks.
08.05.2020 16:52 # 2
Does the 4-digit password specific to the vehicle not work?
08.05.2020 16:52 # 3
toga406
Couldn't it be changed? If
is like this, it wouldn't be useful to disassemble the battery.
08.05.2020 16:52 # 4
datelk
I did not receive password information from the person I bought the vehicle from. What is the method of learning unknown password?
08.05.2020 16:52 # 5
rugger35
Maybe I found something like this:
Switch on the radio and leave volume low, disconnect the battery and leave car for about 15mins then re-connect battery. Get into car and do not touch the radio, power up Blue tooth on your phone again and it should give you the `success` message on dash. You might have to use the four digit code on your phone which is 0000, that`s four zeros. Apparently disconnecting the battery & amp; re-connecting will re-set some of the required electronics for your Bluetooth connection.
Turn on the radio and mute the sound, remove the battery and wait 15 minutes and reconnect the battery. Get in the car, do not touch the radio, activate bluetooth from your phone and the connection message will be displayed on the car's screen. You may need to enter the zero code. It seems that removing and inserting the battery resets the electronic connection required for the Bluetooth connection.
Toga406, I think the advice of the friend is appropriate ..
20 amps in the 207 and 5008. This problem is solved when they remove the audio fuse (same fuses) for 15 minutes and reinsert it. I don't know the model of your vehicle ..
rugger35 2012-06-28 17:41:05
08.05.2020 16:52 # 6
datelk
You have to try. I called the service, they said 1234 or 0000, neither of them did. Surprised!
08.05.2020 16:52 # 7
rugger35
The password has been changed, it is likely that the battery can be disassembled / plugged in. In this case, I think it has a wisdom.
