Bluetooth module
08.05.2020 21:09 # 1
emirksk
Good evening,
While buying the vehicle, the bluetooth module was not working. The salesperson hid the module, asked several places, but couldn't do it.
This is the module,
It's like there's no way I can find a dating. I showed it to the electronics shop, he said, come and see. Burst capacitor, burn resistance etc. in PCB appearance. I could not see.
Is it possible to repair it? It has zero on ebay, but ebay does not ship to Tr. And where is this module located?
08.05.2020 21:09 # 2
Who is going to deal with it when it is repaired, there is a separate issue, brother, and it may also be a problem of not finding the part that needs to be replaced. Unfortunately, this module is available in many peugeot models, not just 207.
08.05.2020 21:09 # 3
emirksk
[QUOTE = sonerkyl] repairs, who will deal with it, there is a separate issue, brother, and it may be the problem of not finding the part that needs to be changed. unfortunately, this module is available on many peugeot models, not just 207. [/ QUOTE]
Thank you, Soner. I will try to heat the chip with a heat gun myself.
Let's say I found a quit, do I need to define from diagnostic?
And in some models, the letter D at the end of my module code was F, S. Do you know the difference?
emirksk 2019-02-12 12:20:59
08.05.2020 21:09 # 4
Try to make a trial order, even if there is a possibility to fix it, you should try. I remember that there is no need for identification from diasonic. The module only needs to be made for tape. The system should work directly after installing the module. unfortunately I have no idea about the codes.
08.05.2020 21:09 # 5
emirksk
Soner teacher, do you know the location of this module? In some places, it is a bit of a trouble to have it removed behind the torpedo but there is no definite information. :)
