Blue smoke
08.05.2020 21:20 # 1
Adem27
Hello friends
My 2006 model 1.90 peugeot partner brand car gets too late at the first start in the morning, after working from the other side, if I do not gas it, it buys and takes it, then it bursts out of it. it certainly doesn't do that, I would appreciate it if you help me.
Adem27 2019-10-16 02:31:17
08.05.2020 21:20 # 2
eran
Blue smoke is normally a sign that the vehicle is burning oil, but it must be done constantly. Should the first smoke in the morning not be white?
08.05.2020 21:20 # 3
eran
08.05.2020 21:20 # 4
KILIC
If it is done at the first start, then it does not emit blue smoke, valve valves may be running away. The cylinder top cover must be removed. Or the glow plug may be faulty. First of all, connect to a computer has an error code. The glow plug can already turn on the malfunction lamp.
08.05.2020 21:20 # 5
Adem27
no white not 3 cuts after 5 seconds of blue smoke
08.05.2020 21:20 # 6
Adem27
There was no oil reduction in the car, there was no room, I just checked, recently the diesel pump's pressure sensor cable was out there, it was like this after installing it, the sound of the engine was different before it was installed, so it sounded like it should have been, but this time it started to force in the first starter and not in the first start. I would be glad if you help me why I did it after installing the diesel pressure sensor
08.05.2020 21:20 # 7
Adem27
I went to the last mechanic, he checked the element with a cable, but did not attach it to the computer.
