BLU HDI DIESEL ENGINE OIL SELECTION
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 5008
08.05.2020 19:43 # 1
Pirsek
2015 model blu, my 5008 owner wanted to know about the oil used when I brought my car to 15000 maintenance, they told me that they used 0w30 ineo or mobil 5w30formula ecs when I looked at the vehicle's booklet, 0w30 acea c1 or c2 was also used in the car's b71 2312 certified oil. insist obtain car mobile 0w30 fullekono me so fat demanded strict and I learned a vehicle's sound artti.b the search of blu HDi two oil that is compatible turkiyede to the motor vehicle which 0w30 total ineo first or valvolin sec exre env c2 dir.kesinlikl oil for yourself forehead
08.05.2020 19:43 # 2
mimit
The only oil available now for Euro6 engines Total ineo first 0W-30, besides the oils for euro 5 engines, I guess that they will release the oils they have developed for euro6 engines soon in mobile and motul, then we have to decide which one is good by trial. Euro5 engine also offers a much quieter engine than mobile 1 esp 5w30 total. At the same time, I did not receive a warning about the emission system even once I used this oil.
I recommend you to get the appropriate oil and change the oil as soon as possible. Even if the maintenance is new, the change will be beneficial, you can only change the oil in the special service outside, they draw the oil in the engine by vacuum and drain it by 85%. The next filling process is already easy. Although the lifetime of the oils used is 15,000 km, I am on the side of the maintenance period being reduced to 10,000 km. as someone who saw the filter after 15,000 km.
03.12.2020 23:18 # 3
Ozdemirli
It has been a long time since this issue has been opened. But I would like to rekindle. I had the first maintenance of my 3008 1.5 blue hdi vehicle at the authorized service. Engine noise increased significantly after maintenance. The motor, which used to be thicker and quieter, has now started to operate in a more robust way. Even if the engine is warming up, it works noisy I think it's about oil. The answers I got from some groups are that the factory oils are 0W30, but after the instruction to the service, 5W30 oil is added. I don't know if this information is correct, but do you think this oil type makes the engine run louder?
13.12.2020 15:00 # 4
matrixss
I went to the service for the first maintenance. Like you said they put ineo esc5w30 oil. At first it seemed to me that it was working louder. Maybe psychological. I got it done in November. The weather is cold, 4-5 degrees may affect the room. For example, it doesn't sound too loud now. Ineo first 0w30 oil is more successful when cold. It has not only low fluidity, but various additives. No oil can prevent the damage caused by cold loading to the engine. It will not fail to protect the engine with the oil. If I continue to the authorized service, I will say that I will bring my oil myself with the excuse of 0w30 oil. They kiss more than oil. matrixss2020-12-13 15:00:53
19.01.2021 10:38 # 5
Ozdemirli
A friend of mine said that the service offered a choice of oil to be put in the vehicle and put the oil selected according to the customer's decision. It even showed me that with the "get offer" option in the MyPeugeot application, there is a price for two different oils.
I also had my first maintenance done in an authorized service in Istanbul last November. But I was not asked such a thing. From this point on, I think there is no standard in services. Because your saying that I will bring my oil to the authorized service supports this idea. How did they react when you said that? I was curious ...
28.01.2021 11:09 # 6
Ozdemirli
Hello,
When I consulted with the authorities, they were told that 5w30 oil should be used for my vehicle with the chassis number. When I asked if I could put optional 0w30 oil, it was said that it might be possible provided that you take the responsibility!
Is there anyone who put 0w30 oil in the authorized service for 1.5 diesel vehicles?
