Blowing in 206 engine, what is the cost of renewal?
08.05.2020 17:23 # 1
djr35
Sa friends, 2003 model 1.4.hdi 206 I have a motor blowing in the car day by day, this blowing increases and the car started to burn oil while on the way, it throws more smoke from the exhaust than it should be. so the engine will be renewed. A couple of friends who understood looked at it, said the blow is too much, so the engine will either be in competition or will be completely renewed. I'd appreciate it if friends write about their estimated cost. thanks in advance .. & nbsp;
08.05.2020 17:23 # 2
Aziz
I don't know if it's the same but 2003 & nbsp; Opel Corsa 1.3 CDTI Enjoy Cars < / span> & nbsp; the cost of the competition cost 1200 TL. & nbsp;
was not spraying officially :) 2012 - 8th is the month price.
08.05.2020 17:23 # 3
djr35
I guess it is not the same as my teacher Opel because some friends say that it costs at least 3000 TL so I said to the friends in the forum. I was going to go to the service anyway, but I thought we had some prior knowledge. still thank you for the answer my dear friend :)
08.05.2020 17:23 # 4
hsnsnl
peugeot service or private service, when you say service, my teacher 3000tl too yaw friend as I said, I need to go up to a figure as I say .. I can give my teacher service price .. if you think you are in Izmir ..
08.05.2020 17:23 # 5
hema123
[QUOTE = Aziz] I don't know it's the same but 2003 & nbsp; Opel Corsa 1.3 CDTI Enjoy Cars & nbsp; the cost of the competition cost 1200 TL. < span style = "line-height: 1.4; white-space: pre;"> & nbsp;
not spraying officially :) 2012 - is the price of the 8th month.
1200 does not compete. only the segment may have been discarded. Today, the cost of a solid recipe ranges from a minimum of 3,500 to a maximum of 5500. & nbsp; piston-piston ring set & nbsp; 500
-circulation water pump 250
-oil pump 250
-block recess 500
-set valve and top cap work 500
-injector maintenance 750
-pump maintenance 750
-oil + antifreeze 100
-fuel + air + oil + pollen filters & nbsp; 100
-triger set 250
-working 500
total: 4650
three down-five up, these expenses must be made. there will be more, not less. & nbsp; 1200 lira gallery even looks difficult.
my regards .
08.05.2020 17:23 # 6
Aziz
[QUOTE = hema123] [QUOTE = Aziz] I don't know it's the same but 2003 & nbsp; Opel Corsa 1.3 CDTI Enjoy Cars & nbsp; the cost of the competition was 1200 rubles. & nbsp;
It was officially spraying not blowing :) 2012 - 8th month price.
does not compete to 1200. only the segment may have been discarded. Today, the cost of a solid recipe ranges from a minimum of 3,500 to a maximum of 5500. & nbsp; piston-piston ring set & nbsp; 500
-oil pump 250
-block recess 500
-triger set 250
-working 500
total: 4650
my regards .
So much detail came out from the sentence I used as Rektefe, I guess it would help a good friend. & nbsp;
If I burn the engine, I will remember what you wrote. but grinding is sufficient for blowing. With your definition, Segman has a competition of 1200 lira with my definition ...
08.05.2020 17:23 # 7
goktug
[QUOTE = djr35] Sa friends, 2003 model 1.4.hdi 206 on my car, there is blowing on the motor day by day, this blowing is increasing, the car started to burn oil on the road, throwing more smoke from the exhaust than it should be. so the engine will be renewed. A couple of friends who understood looked at it, said the blow is too much, so the engine will either be in competition or will be completely renewed. I'd appreciate it if friends write about their estimated cost. thanks in advance .. & nbsp; [/ QUOTE]
& nbsp; how many thousand of your vehicle?
08.05.2020 17:23 # 8
muku
I did the gasoline 1.6 206 two days ago, I was hot, I gave the current prices when I got the bill, but mine is in the circulation of the radiator. I gave 3500 TL. may be more expensive
08.05.2020 17:23 # 9
hema123
[QUOTE = Aziz] [QUOTE = hema123] [QUOTE = Aziz] I don't know the same but 2003 & nbsp; Opel Corsa 1.3 CDTI Enjoy Cars & nbsp; competition kept the cost 1200 tl. & nbsp;
was blowing in not blowing officially :) 2012 - 8th month price.
-oil pump 250
-block recess 500
-triger set 250
-working 500
total: 4650
my regards .
If I burn the engine, I will remember what you wrote. but grinding is sufficient for blowing. With your definition, Segman is with the definition of 1200 pounds of competition. , valve training, valve tire replacement, and cylinder head gasket replacement can be resolved to these amounts. There are also situations requiring full competition such as bed wrap, piston wrap, cover cracking, arm removal, block cracking. but in such cases, blowing is not observed, since the engine cannot already start. I learned the situation from you if I burned the engine. It means doing the recipe by not doing the expenses listed in the invoice formation, but using the oldest of everything.
my best regards.
08.05.2020 17:23 # 10
_semihk_
I take my money after I give them the money, I will enjoy my engine ... here is the link
http://www.peugeotmarket.com/206-14-hdı-komple-motor,pr-400.html
08.05.2020 17:23 # 11
samet2461
The full engine of my vehicle was made, the turbocharger pump trigger circlip piston injector was full everything was made, there was a 4850 TL bill. really made successful
