blowing hot air from ventilation
08.05.2020 15:44 # 1
caffe
Greetings friends, I will ask you something. In 307 xt (digital air-conditioned), the air is blowing hot air from the air conditioner when it is off. The temperature is usually a little over 90 and the hood is always very hot I don't know all this is related but why does this happen or is it something normal?
08.05.2020 15:44 # 2
It's a normal situation. As you described in all of us. What you can do is to turn off the air vents.
08.05.2020 15:44 # 3
Digital air conditioners have an arrow in the shape of a bow, press it. In the part of the vehicle picture, that arrow will appear on the windshield, when air entry is blocked.
respects
08.05.2020 15:44 # 4
When it brings the degree to the lowest level, does it come out from the ventilation nozzles again?
It is very normal for the hood to be warm. Vapors emerge from the hood according to the place where it heats up in the same way as the blade. As a result, the stove is burning under it :))
08.05.2020 15:44 # 5
metin
it's happening to me too
The last time you turned off the air conditioner, it continues to blow small. Either you turn the air conditioner down, turn it off, turn off the air or cut the air inside and have the key to circulate the air.
08.05.2020 15:44 # 6
caffe
Actually, I did not have much trouble with him, I just wanted to learn about him, a messenger in the engine cooling or a radiator problem. Normally, I turn the ventilation to the closed position and the problem ends.
08.05.2020 15:44 # 7
caffe
Meanwhile, since the air conditioner is summer, it stops at a low level.
08.05.2020 15:44 # 8
Haksen016
the same thing happened with me. Thanks for the information. al.
08.05.2020 15:44 # 9
metin
[QUOTE = caffe] Actually, I didn't have a problem with it, I just wanted to learn it from my engine, or a reporter of a problem in the radio. Normally, I turn the ventilation to the closed position and the problem ends.
the temperature of the engine is hot in normal weather, do not worry. Sometimes when I open the hood, I can't even hold the iron I will put under it to stay open, it gets so hot
08.05.2020 15:44 # 10
fTh206
[QUOTE = caffe] Greetings friends, I will ask you something in 307 xt (digital air-conditioned) while the air conditioner is off, it blows hot air from the ventilation. The temperature is usually a little over 90 and the hood is always very hot I don't know all this is related but why does this happen or is it something normal? [/ QUOTE] hot blows in hot weather, mine is natural so :))
08.05.2020 15:44 # 11
ismail ozdemir
In the off position, the engine does not want the temperature, it is coming, it is not necessary to prevent it.
08.05.2020 15:44 # 12
caffe
What is a ventilation system not air conditioning? There is a separate ventilation system, other than air conditioning ...
08.05.2020 15:44 # 13
semih
check the circulation constantly. best regards.
08.05.2020 15:44 # 14
ismail ozdemir
[QUOTE = caffe] What is it that you call a ventilation system rather than an air conditioner?
Of course, there is only no air conditioner. When you press the ac button 1 time, the ac works, if you press the same button, the car will go to normal ventilation system.
08.05.2020 15:44 # 15
denizcAn
Despite Being A 2011 Model Even In My Vehicle, While The Heater Is Closed, Hot Air Comes From The Grills. I think the temperature of the engine. So it's normal. I shouldn't be too peeping.
08.05.2020 15:44 # 16
toprakk
you will close the air conditioner outlets. you open it in use
