Blowing fan Not working. RESOLVED ...
08.05.2020 20:27 # 1
Peugeot35
Yesterday evening after turning off the air conditioner, I will turn on the air conditioner at noon, I said the fan does not blow, does not work at 4 levels, but it activates the air conditioner.
I took it to the private peugeot service, turned the tap valve a few times right and left, the resistance will be broken, I will do 150 TL in repair.
How do we break down to where we stopped? I also changed the fuse, click on the 18 numbered 40 cigarette on the motor side.
Does anyone know where is the resistance?
Peugeot35 2017-07-14 14:43:30
08.05.2020 20:27 # 2
dejawu1978
I think I was there talking rezistand get past the front console of the front torpedo putative there could be achieved
08.05.2020 20:27 # 3
Peugeot35
The fan motor is diagonally right above the pedals. There is no resistance behind it. I wonder where this piece is!
08.05.2020 20:27 # 4
Peugeot35
[QUOTE = Peugeot35] fan motor stays diagonally directly above the pedals. There is no resistance behind where this piece is! [/ QUOTE]
I think this is the piece
08.05.2020 20:27 # 5
Peugeot35
Friends with 307 have such a problem and does anybody solve it? or does anyone know exactly where the resistance element is?
08.05.2020 20:27 # 6
[QUOTE = Peugeot35] 307 friends who have such problems and have their own solvers? or does anyone know exactly where the resistance element is? [/ QUOTE]
my teacher may have many reasons for this. There are many topics in the forum
08.05.2020 20:27 # 7
your problematic piece is one of them
1-moon-shaped piece is distorted in the picture
Track number 4
2- the part in this picture is the part you said, teacher
Track number 5
08.05.2020 20:27 # 8
Peugeot35
thanks for your help. thank you soner, who finally found it under the torpedo, thanks to where we found the resistance, but it did not make sense to me because there is no thick under the torpedo when there is a thick pipe when you start the engine that provides air circulation, there is a part in the front of the fan blower motor, it is independent of the motor, this is the problem because it is independent. I do not think so.
According to the special service resistance is broken, he said that he will make the part you mentioned with a price of 150 TL.
Peugeot35 2017-07-14 00:55:13
08.05.2020 20:27 # 9
vpro
If the 4th stage worked, I would say that the thermal diode on it is broken, but it can still be tested as follows.
The thermal resistor on it can be cut and short-circuit by wire can be tried.
08.05.2020 20:27 # 10
Peugeot35
While passing the industry today, I saw the newly opened peugeot authorized service went, I explained the problem, the resistance was broken, it was the same diagnosis, the resistance was under the torpedo, it is not believable. Smile I asked if it should be on the fan motor, he said, it is on the fan motor of automatic air conditioners. I wonder if it is the piece in the picture?
he was very honest about the price, he called the particle, he received 45 tl price, he said 50 tl in workmanship to 90 tl. at the same time, the resistor can be robust, it can also be a problem with its sockets.
08.05.2020 20:27 # 11
Peugeot35
Erase everything from the beginning.
If 1-2-3-4 fan blowing stages are not working, the solution is below.
IT IS POSSIBLE TO DO THESE PROCEDURES WITHOUT TORPIDO REMOVED ...
First, we start the car, press the air circulation button, the mouth of the thick pipe opens, so we cantop it.
we pull back the seat on the right and open the side cover and insulate. It is very comfortable to work with left hand.
The name of the visible part lies in the RESISTOR (resistance), turning it clockwise to remove it, and the problem arises. cable and socket are hot and melted. There is melting in the region where the resistance has socket number 1, but not much RESISTANCE is solid! I woke up the cables and the fan started working. Of course, temporarily, because the socket has to be changed and to find it in the socket is the main problem.
If the work done is mine, you can have 50 TL and 100 TL for this process. The socket system is secured by finding and revising the socket.
Peugeot35 2017-07-19 13:10:58
08.05.2020 20:27 # 12
Peugeot35
Friends Anybody have the idea that I couldn't find the molten socket of the resistance? or where can we find this socket? Unfortunately, peugeot made the car but did not solve its chronic problems.
08.05.2020 20:27 # 13
Peugeot35
date.
08.05.2020 20:27 # 14
If I find this faulty socket with my faulty part, I will send the link in it
08.05.2020 20:27 # 15
I hope I found it as a teacher, I hope your work will be high.
08.05.2020 20:27 # 16
akk0212
my 307 also stopped blowing last summer. He kept 10 lira
08.05.2020 20:27 # 17
Peugeot35
[QUOTE = sonerkyl] I hope my teacher found it as a set, I hope you will see your job.
Soner Hodja, you are the only one. How could I find this socket? When you take your hand, I would like to take both the resistance and the socket together. Thank you very much.
Peugeot35 2017-07-20 17:40:31
08.05.2020 20:27 # 18
you are welcome my teacher if we could help us Smile
08.05.2020 20:27 # 19
Peugeot35
[QUOTE = akk0212] my 307 stopped blowing last summer, I showed it to the electrician, the socket said melted, took a little cable 10 minutes later said okay, it has been working for 1 year without any problems. It costed 10 lira [/ QUOTE]
My teacher added a certain place to work in 10 minutes. electrical work is not a joke, the amount is big. construct. He made healthy bits.
Peugeot35 2017-07-19 18:53:45
08.05.2020 20:27 # 20
Peugeot35
We have ordered from aliexpres but it is not less than a month entrusted to this, so I said it would not be good to have a air conditioner at 40 degrees without air conditioner while the air conditioner was available.
WHAT IS DONE.
1- I disconnected the thick cable on the melted side of the socket from the socket. so cable number 1
2. I opened a slot with a drill just before the male plug # 1 of the resistance.
3. I connected the green wire that I just pulled on the brown cable in the picture and I wrapped it with electrical tape and put the socket on the resistor, instead of the resistor, it was inexpensive workmanship and solid work.
Peugeot35 2017-08-01 21:21:56
Page : / 2
