Blow Off selection
08.05.2020 17:56 # 1
TroubLe59
hello friends 206+ I want to blow off our HDi Envy model vehicle emergency help?
If I bought the original hks blow of, it was difficult and expensive to install, it had the installation of blow off price, instead there was an electronic or exhaust mounted piece, but what would be the most similar sound if it was not the same sound?
08.05.2020 17:56 # 2
TuNeR_32
electronic turbo http://www.youtube.com/watch?v=AsnRENjXVmQ
08.05.2020 17:56 # 3
g-demir
The original blow off assembly in the diesel engine is somewhat arduous. If you plug in electronics, the sound is similar, the vehicle will not be tampered with. What happens in the exhaust has nothing to do with blow off, just whistles
08.05.2020 17:56 # 4
samet206
I had a subject before, I was definitely against the diesel vehicle, I am against this kind of operation. If you get a sound similar to the original, at least if your car is not played, as soon as you end up buying it in the original, it will not give you any pleasure other than the sound that will help your vehicle like that, there is no need for an adventure with an electronic product.
Many products like this are available in the market.
http://www.sahibinden.com/ilan/vasita-aksesuar-tuning-otomobil-arazi-araci-elektronik-blow-off-elektrikli-blow-of-70836646/detay/
08.05.2020 17:56 # 5
TroubLe59
[QUOTE = samet206] I had the subject before, I was definitely against the diesel vehicle, I am against this kind of operation, but this is my winter idea. If you buy and install it, you will get a sound similar to the original, at least if your vehicle is not played, as soon as you end up with it, if you buy it in the original, you do not need any adventure when it comes to sound with an electronic product.
thanks :) I will do detailed research tomorrow
08.05.2020 17:56 # 6
TroubLe59
[QUOTE = g-iron] Original blow off assembly in diesel engine is a bit difficult. If you plug in electronics, the sound is similar, the vehicle will not be tampered with. The exhaust has nothing to do with blow off, just whistle [/ QUOTE]
When I heard a whistle, I thought that a friend said he had it in his chest.
08.05.2020 17:56 # 7
TroubLe59
[QUOTE = TuNeR_32] electronic turbo http://www.youtube.com/watch?v=AsnRENjXVmQ [/ QUOTE]
thank you need a sound from the outside or something :)
08.05.2020 17:56 # 8
My teacher is going to a very hard and long mechanic in the installation of blow-around around 100 lira. I think you will go to the turbocharger and spend 300 lira there.
08.05.2020 17:56 # 9
murat328
As someone who uses it, I think it does not relieve the turbo, it compresses and the malfunction lamp comes into operation, it cuts the gas as a vehicle. I haven't been using it for 1 year.
08.05.2020 17:56 # 10
[QUOTE = murat328] I think that as someone who uses it, it does not relieve the turbo, it compresses and the fault lamp comes into operation, it cuts off the gas as a vehicle.
You say Big smile
