Blackout Interior Rearview Aynam Broken
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 19:50 # 1
mscdeejay
As seen in the picture, the mirror remained in my hand as a result of an accidental blow :)
You can click the link below to see more clearly
mscdeejay 2016-06-15 04:20:38
08.05.2020 19:50 # 2
teacher, if you want a good result, I recommend you to use one of the products I have given in the link.
https://www.glassmakro.com/orta-vizkozlu-uv-yapistirici-cam-metal-100-gr.html
08.05.2020 19:50 # 3
ARDADOGAN
Take a fine sandpaper to your hand, make a fine sandpaper, remove it from the old adhesive, but gently wipe it with a damp cloth, then take a patex when you dry it. I
08.05.2020 19:50 # 4
error
if this happens, if there is a rain sensor in the car , go to the glass shop without tampering with the mirror "sensor under the mirror". error 2017-06-05 02:46:01
