Black smoke from exhaust ...
08.05.2020 19:47 # 1
407 ERHAN
hello, my 407 car is 1.6 diesel, when I first start it when the engine is cold, it throws black smoke from the exhaust and there is a bitter, sharp smell, but this smoke stops immediately after starting, when the engine is warmed up, it does not occur during the first start and there is no smoke throwing on the road. No, this is normal or is it a malfunction indicator guys, I would be very glad if you could help, thanks ...
08.05.2020 19:47 # 2
erhan abicim how many km of the vehicle is now black smoke can often be caused by parts such as egr valve. If there is not a very extreme situation, I think, do not tamper with the masters. In my opinion, try a wür enejector cleaner fuel additive. it might be a little bit useful.
08.05.2020 19:47 # 3
407 ERHAN
Soner brother, thank you very much for the information you have given, my vehicle is currently at exactly 175000 km, it has already started to make this smoke recently, it was not before, I am constantly getting my fuel from the same place, shell v power nitro, I am very meticulous about it, the smoke is just when the engine is cold For example, it does take off a little in the morning for the first time, just a few seconds, then cuts off, does not emit smoke on the road as far as I know ...
08.05.2020 19:47 # 4
You're welcome, brother, then, no problem, my teacher probably started to drip injectors. If you do not feel like oil reduction in the vehicle, you can take it to a master if you feel comfortable with peace of mind. you can even find many detailed explanations about this topic on the internet.
08.05.2020 19:47 # 5
407 ERHAN
Thank you very much bro, no oil reduction, good day, thank you ...
08.05.2020 19:47 # 6
boran04
dude I've had the black smoke thing. mine was a little different. the traction had fallen, the ramp I finished with the 5th gear was hard with two. Since there is no service, a few masters told him some money, injector, some turbo, some filter, and he said 500 TL when he called it money. In this forum, I followed the advice of a friend, I found the solution here :) Egr Walf and iron pipes connecting it to the turbo. One of them was cracked. Gone welded the pipe of the doblo 50 TL, workmanship is better than the car now :)
08.05.2020 19:47 # 7
seiko35
My brother has a cleaner in the warehouse and the problem is solved.
08.05.2020 19:47 # 8
Efkan
The same thing happened with smoke throwing in me, but the vehicle decreases water and there is no problem with the water leakage.
08.05.2020 19:47 # 9
Utkukaraca67
I have the same problem with me, I changed the last drbimeter in the smoke, there was not much in the traction. Which pipe can this help you
08.05.2020 19:47 # 10
noscream
I agree with the determination. Most likely the injectors started to voiding, the injectors doing voiding have a damage to the engine, I had read somewhere, writing that it damaged the pistons! Apart from that, Berner or Würth (my preference Berner really noticed, after Würth, it seems that the traction has dropped) when the fuel additive improves, if it does not, then the injectors may need maintenance. My vehicle has a very small drop in traction on the 116kb, a little bit of black smoke when it loads! The master tested the EGR (there was no EGR error on the onboard computer either), he looked at the turbo, said no problem, the latest injectors remained!
08.05.2020 19:47 # 11
hzr206
Obviously, I had a similar problem, when one of the injectors changed and after that I drove my car, I had noticed a little bit to completely remove the institutional connection of the injectors.
08.05.2020 19:47 # 12
407 ERHAN
Hello friends, thank goodness, thank God my car has improved, I have had it done for about 4 months, but I had a new opportunity to write an answer, I have revised the injectors of my vehicle, only the consumables of the injectors have changed, so the internal parts have changed as a team, the pump master took a total of 1100 TL, 1000 TL material, 100 TL workmanship, there is no trace of smoke in my vehicle, the traction has increased and the fuel consumption has decreased considerably, I can tell you that now, around 4.60 TL in diesel shell, 28-30 kurus in urban calm use, and on average 90- If you go with 100 km, it burns 18-20 cents, and the average fuel consumption on the road computer shows as 100 km / 5.4 liters, because my urban use is more, which corresponds to 25 cents, I think it is quite reasonable values for a diesel vehicle with approximately 1500 kg. ... 407 ERHAN 2017-08-09 04:35:38
08.05.2020 19:47 # 13
I am glad that erhan abicim vehicle has improved. fuel values are really good
08.05.2020 19:47 # 14
407 ERHAN
Thank you Soner, thank you, I was in Ankara in July, but I could not get much permission because the jobs of Kastamonu deed was quite intense due to urban transformation, and I was in a hurry again, so I spent the rest of my leave in my hometown of Konya. I had no opportunity to stop by, Soner brother, do not look at my fault, do you believe that I did not even have the opportunity to balance my vehicle, but you are always in my mind, once again when I come to Ankara, I will definitely come to meet you, but write back next year but I will come back with hope to see you again, I wish our hearts to be very good. I wish you good health and good health ... 407 ERHAN 2017-08-09 04:45:50
08.05.2020 19:47 # 15
[QUOTE = 407 ERHAN] Thank you Soner, thank you, I was in Ankara in July but I could not get much permission because the works of Kastamonu deed was quite intense due to urban transformation, and I was able to spend only a few days in Ankara, and it was also in a hurry. I spent in Konya, so I had no opportunity to stop by, Soner brother, do not look at my fault, believe me, I did not even have the opportunity to balance my vehicle, but you are always on my mind, once again when I come to Ankara, I will definitely come to meet you, but write next year, but I will come back, hope to see you again. well, take care, stay healthy, I wish you well-being ... [/ QUOTE]
Why, brother, it was not a problem, then I wasn't in Ankara :) I went to Akcakoca on vacation. Nasip, now, maybe I will drop my way to those sides, I will come to you :) Take care of yourself, my brother.
08.05.2020 19:47 # 16
taksicicocuk1
If you find that there is a yellow box oil additive called brother rom energizer, you must definitely try to cut the smoke and put it in one by one.
08.05.2020 19:47 # 17
407 ERHAN
I always wait soner, Kastamonu is considered to be neighbor to Ankara, and now we have Ilgaz tunnel, you will not have to overcome the big mountain. 407 ERHAN 2017-08-09 10:29:26
08.05.2020 19:47 # 18
407 ERHAN
Thank you taksicicocuk1 my friend but as I said, the injectors are finished now, when some parts change, the smoke stopped but still in my mind, thank you again. 407 ERHAN 2017-08-09 10:23:58
08.05.2020 19:47 # 19
taksicicocuk1
Good luck abey
08.05.2020 19:47 # 20
Utkukaraca67
Does this smoke-cutting oil additive really work. Anyone try. The institution is throwing the vehicle you know
Page : / 2
