Black Smoke and Traction Problem
08.05.2020 21:20 # 1
kronos
Good forums for everyone,
First of all, my car is 2006 1.6 HDI 407, it has been 2 months since I bought the car. I have all the maintenance of the vehicle. Last week, my car burned out a motor warning. I showed it to the master, said EGR. EGR maintenance and cleaning was carried out after 2 hours of work on this day.
However, the problem of throwing black smoke in the exhaust still continues. And while driving, it feels like there is a choking or a loss of power in the engine. There was also an injector. Those who said there were cracks in the pipes. I checked it again today, there is no oil or water drop. What kind of solution should I follow?
Or is there a good master you know in Izmir?
08.05.2020 21:20 # 2
First of all, welcome to us. If the vehicle has low traction, air filter boiler and hoses - turbo hoses should be checked thoroughly, crack may be leak or not fit properly. There is also an air flow meter cleaning - there are vacuum hoses entering this part controlled by the turbo solenoid valve, they may be torn or disconnected. And finally, there is an injector additive, take a quality brand like würt and put it on a quarter tank, add euro diesel fuel 100-150 TL, then use low gear high speed 15-20 minutes on a road where you will not be punished like the ring road. Of course, if the fuel tank is very dirty, there is a possibility of spoiling the diesel fuel pump and injector, so I have to make the decision whether it is worth it to take the risk. If it causes problems, it can cost you a lot.
08.05.2020 21:20 # 3
kronos
Thanks I will make trials and checks and inform :)
08.05.2020 21:20 # 4
You're welcome.
08.05.2020 21:20 # 5
kronos
Greetings again,
Yesterday, we achieved checks with friends on the ranks at work. The pipes were intact. I bought würth before I went to industry. I added it to the warehouse. I started the car with a high speed in 3rd gear on the road. A huge cloud of black smoke came up as if I was prancing from behind. I extended the road a little more and moved quickly in 2nd gear at high speed. There was a larger black smoke pulse than the previous one. I set off with my car this morning. I traveled about 15 kilometers. There is no problem for now. The traction of the vehicle also improved. Thanks for the recommendations.
