Black smoke
08.05.2020 15:40 # 1
deamod
Hello friends ...
When I start and sometimes the gas sometimes exceeds 3000 cycles at a time, almost the gas is thrown out from the exhaust of the vehicle, that is, it emits a lot of gasoline. What is the reason of this?
08.05.2020 15:40 # 2
Have you checked your spark plugs? Worn or incorrect spark plug may be installed.
08.05.2020 15:40 # 3
Carmania
First of all, it may be related to everything, even with valve valves.
08.05.2020 15:40 # 4
ugur_xs
it burns raw petrol then it probably means spark plugs are not fired as desired
08.05.2020 15:40 # 5
1. Fuel may be of poor quality.
2. Your air filter may be clogged.
3. The throttle may be contaminated.
4. The spark plugs may have lost their function.
5. The exhausts may have started to rot.
6. When the engine is cold, you push the vehicle too hard.
7. ...
Bring more to you now.
Embarrassed
mustiii 2011-07-16 02:56:12
08.05.2020 15:40 # 6
berk2309
If you do it when the engine is cold, you will blow up too much or white smoke, not black smoke, will come out until the engine warms up at first.
08.05.2020 15:40 # 7
ukendirli
08.05.2020 15:40 # 8
Muhammet CAKIR
[QUOTE = mustiii] 1. Fuel may be of poor quality.
7. ...
Embarrassed
[/ QUOTE] Thumbs Up
08.05.2020 15:40 # 9
sinka251
throws evaporated water in the exhaust, it is not gasoline
