black smoke
08.05.2020 21:04 # 1
Dogan kucukarslan
307 1.6 hdi one of my injectors had a problem on the stamp
They said there were two in two and they cleaned the 4 injectors, the nipples changed and the tactics now started to blow the black smoke.
08.05.2020 21:04 # 2
If there is not such a problem in terms of injector, injector settings may not be good. You have to check egr and turbo hoses.
08.05.2020 21:04 # 3
GokhaN
at which cycle it discharges black smoke. Caused by catalyst egr etc because it was recovered in the vehicle
08.05.2020 21:04 # 4
Dogan kucukarslan
When I run in the morning, the first blue smoke then corrects my heat, beats at 2500 3000 cycles
08.05.2020 21:04 # 5
whisky
Because of the rich mixture, it seemed like it was blowing black smoke in those times.
08.05.2020 21:04 # 6
Dogan kucukarslan
the institution and the lifter and the sibolarin made the institution because he said that we will make ptesi carbon clear and see what the results will be
08.05.2020 21:04 # 7
whisky
If there is an engine malfunction due to any oil burning, oil reduction or mechanical parts in the vehicle, it is not recommended to use Carbon Clean, it is useful to have a good look.
08.05.2020 21:04 # 8
Dogan kucukarslan
Well, according to what I have said, no malfunction, no malfunction code.
Now, I said I would have a little bit of a pump.
08.05.2020 21:04 # 9
Cemus
I quit smoking problem in the morning, the service broke the car even more.
