black smoke !!
08.05.2020 17:12 # 1
DS002
when my car peugeot 307 1.4 hdi xr 2005 model & nbsp; ramps & nbsp; & nbsp; overloaded gas between 3000-4000 cycles, when the gear is pressed up to 4000 rpm, what is the problem? There is no problem with the traction of the car. Is it normal to sound like a whistling sound from the turbo?
08.05.2020 17:12 # 2
Bugra
black smoke is normal in diesel vehicles. Of course, if it beats like a black train, it means trouble. to my knowledge there is a solution for the egr valve. I can't say for sure in the whistling sound, but I think there is a leak from the turbo pipes. & nbsp;
more knowledgeable friends will be helpful.
08.05.2020 17:12 # 3
DS002
the traction of the car is fine. I finish the ramp with 140km speed at the same speed. There is no problem.
08.05.2020 17:12 # 4
Bugra
http://forum.peugeotturkey.com/forum_posts.asp?TID=25095&title=kara-duman
if you want to review this topic.
08.05.2020 17:12 # 5
Serkan
It can be related to fuel. I always fill the tank completely. After getting it from some stations, smoke increases and in others it decreases a lot.
08.05.2020 17:12 # 6
DS002
I wonder if it could have been my problem, my problem was 12,000 km after the last maintenance.
08.05.2020 17:12 # 7
DS002
I do not buy fuel from a fixed place, which station would you recommend?
08.05.2020 17:12 # 8
Serkan
Even if it is not in terms of maintenance, I recommend you to make your maintenance as 10.000 km or 1 year. As a fuel, the station is more important than the brand, you need to find a reliable station in your region. There is a station operated by Totalin, which is close to me.
08.05.2020 17:12 # 9
DS002
I understand that my bidet car could have been injected in 108 thousand. How much will it cost if I clear it?
08.05.2020 17:12 # 10
tellotello
I suggest you buy and try GTL additive fuel from a few tanks Shell. Try to finish the tank (without being on the road) before you buy it, so the purpose is to have fuel in different cetane in the tank. Do not be afraid that fuel consumption may increase slightly with this fuel. A friend, who has peeled off the maintenance, replace the oil, oil filter and other filters every 10,000 km, especially the contaminated air filter can cause you trouble. If the fuel does not go away after the incident, you turn to other solutions. I think if there is no problem with traction, it may be from fuel. By the way, which climbs are entering with 140 & nbsp; "LOL". Glad that our tools can do 140 & nbsp; "Smile"
08.05.2020 17:12 # 11
DS002
Do you know the Şile Ömer ramps? and I see the speed of 150 km clearly. After trying the fuel you want to try :) I will report the result from here. Do you have any information about the whistle sound of the bidet turbo?
08.05.2020 17:12 # 12
Serkan
Sir, have the maintenance done as soon as possible, then test again, check the bidet turbo hose is it OK?
08.05.2020 17:12 # 13
DS002
If you say the turbo lubrication hose, it should be 5,000 km or so.
08.05.2020 17:12 # 14
Serkan
Fork hose coming out of the air filter is on the engine
08.05.2020 17:12 # 15
DS002
I understood that I would check him too. Bidda said he is glad he made 140, but yours aren't going up to that speed?
08.05.2020 17:12 # 16
Serkan
My car 206 1.4 HDi 140-150 comes out comfortable, I haven't tried more
08.05.2020 17:12 # 17
DS002
the same is mine, but I guess the friend's vehicle doesn't come out.
08.05.2020 17:12 # 18
DS002
I will put the same pictures as yours in my car, and I will see you soon. I have 16 thick base rims, I see it with me on the carpet.
08.05.2020 17:12 # 19
DS002
And if there is a shortage in the hose, does it not fall out of traction?
08.05.2020 17:12 # 20
Serkan
My hose was torn but I didn't feel a traction
Page : / 2
