black smoke .. !!!
08.05.2020 17:04 # 1
samet2461
friends, I ask a lot of questions, but I do not know the diesel. My car has a 1.4 HDI engine with zero turbocharged injectors, but when it gives a lot of gas and even gives gas where it stops, it throws black smoke when it passes 3,000 cycles. And while I am on the road, I press the gas to the end, looking in the rearview mirror, throwing black from the exhaust. I don't understand why it went. "C samet2461 2012-10-05 21:26:40
08.05.2020 17:04 # 2
fatihgg
What is the maintenance status of the vehicle. When was the last maintenance you performed? The car is a few km.
08.05.2020 17:04 # 3
samet2461
[QUOTE = fatihgg] What is the maintenance status of the vehicle. When was the last maintenance you performed? The vehicle is how many km. Are you picking up where you know the fuel? First of all these are needed to help you:) [/ QUOTE]
oil and oil filter have not changed even more than 500 km. The vehicle was built at 201,000 but the engine and turbocharger was installed zero. I take the fuel from opet. & nbsp;
08.05.2020 17:04 # 4
berk2309
I think your problem can be from & nbsp; pump & nbsp; or injectors & nbsp;
08.05.2020 17:04 # 5
samet2461
[QUOTE = berk2309] I think your problem may be from the & nbsp; pump & nbsp; or injectors & nbsp; [/ QUOTE]
I forgot to write brothers but it has changed in the injectors. the person I bought the engine of the vehicle changed everything on the invoice, kept 4,750 TL. & nbsp;
08.05.2020 17:04 # 6
berk2309
the pump may be out of adjustment. turbo hoses may be a problem. If the service is not over 1 year
08.05.2020 17:04 # 7
feline
diesel car throws black smoke, what happened?
08.05.2020 17:04 # 8
berk2309
In the diesel smoke, my brother does not throw it after 3000 cycles, it has to be forced very easily. But the big bolt will be pulled, then the diesel will cig
08.05.2020 17:04 # 9
spearo
when the injectors change, new injectors may cause problems if the engine is not introduced to the engine, the vehicle is operating the injectors according to the values of the old injectors. The vehicle from the fuel pump never blows black smoke.
08.05.2020 17:04 # 10
ssertbakan
White Smoke = Injector
Black Smoke & nbsp; = Catalytic Converter
If we assume that the engine is zero & nbsp; and the injectors have been set, the converter remains 200,000 km old.
08.05.2020 17:04 # 11
loiz
the first time you press it, it is normal to have a black smoke while eating the gas, and if you keep pressing the black smoke while holding the gas, have your injectors checked ... most likely it is done by the injector, if one of the orings of the exhaust manifold is burned by the hot gas coming from the egr, it also does it from it. A catalyst of a vehicle should be checked as well .. see if the turbocharger is throwing oil, disconnect the hose and gap the shaft with the manual procedure.
08.05.2020 17:04 # 12
pt206
it throws some amount when it is loaded into the first gas, but if it constantly throws black smoke constantly, there is a problem.
08.05.2020 17:04 # 13
samet2461
[QUOTE = pt206] throws some amount when it is loaded to the first gas, but if it constantly throws black smoke continuously, there is a problem. [/ QUOTE]
I am doing a black smoke, then it does not.
08.05.2020 17:04 # 14
Peugeot306
My opinion is the rich mixture. Possibility of Being in Diesel Vehicles I know higher and normally.
