Bitüself hk
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 17:20 # 1
Mehmet38
Hello friends
I plan to insulate at the appropriate time. I will start collecting kitchen materials. How do you think the price of the product in Link?
http://urun.gittigidiyor.com/yapi-market/ bituself-noise-and-water-cutting-band-75232119
08.05.2020 17:20 # 2
Alicilik
Bauhouse and Praktiker 20cm * 10mt si 49tl teacher I bought two balls, one ball is enough for the sheet metal of the doors. I am planning to make luggage and floor and ceiling with the other one, of course I will buy more "Big
Sure You do not need to buy a sponge acoustic sponge for sound insulation. I dismantled the white sponge on the vehicle and cut it accordingly, and I crossed the edges with double-sided thick tape, I adhered to the doors, the cold film is not coming anymore. Reviews
08.05.2020 17:20 # 3
206x-line
If we can see if there is any application video for roaming
08.05.2020 17:20 # 4
Alicilik
[QUOTE = 206x-line] If we can see if there is a video application on the app [/ QUOTE]
Well, I had a lot of plans when I applied my teacher. I had to do it alone. I don't have a thought account "Big I just covered the inner sheet of the doors in 2 days. I also sponge acoustic. At the same time, I arranged the cables of the sound system and stole a lot of time at the front doors.
Of course, this is not directly applied. First we clean the door thoroughly with thinner, otherwise the inside of the door is very dirty and it gets the stickiness of the pitch.
2lt synthetic thinner
300gr top cover
1 ball bitüself tape 20cm * 10mt
15mm double-sided sponge tape < br> 3mt 10mm acoustic sponge. I bought a rubber door clip from sevista.
08.05.2020 17:20 # 5
Mehmet38
I have supplied the clips. I also need to change the speakers. There are original cassette players in the car right now. Since my budget doesn't allow to buy them all at once, I will buy speakers for the front and rear doors first. I want the system to be satisfactory. I want the system to be satisfactory without the amplifier. I have no interest but you use it at high volume when there is space (No wiring in the back doors)
08.05.2020 17:20 # 6
niniv
Unfortunately, if you are going to replace the existing speakers, you cannot get efficiency.
Since the doors are plastic, the sound is not clear. I made my own 307 me
The sound increased but the quality decreased. Now I have a wooden plank in my head
Otherwise, when the doors are moaning a lot.
I tried I have to pass all the doors again :( niniv 2014-05-06 23:36:53
08.05.2020 17:20 # 7
barishrocker
[QUOTE = niniv] If you are going to replace the existing speakers, unfortunately you cannot get efficiency.
I tried I need to pass all the doors over again: ([/ QUOTE]
There is no need to support it with wood. You attach the insulation plate and heat it, it is like concrete. It is like a monster when you cut the metal sheet round and attach the speaker with a pulley.
