Bite sound in the brake
08.05.2020 15:58 # 1
What is the reason for this? It is natural or is it a problem?
08.05.2020 15:58 # 2
Finished by
08.05.2020 15:58 # 3
metin
If you can come to the meeting early on Saturday, we will have your hawk peugeot murat brother and I will have them look at the brakes together.
Mine starts to sing spontaneously after a while on the way.
08.05.2020 15:58 # 4
New pads have changed, or is it time for maintenance?
08.05.2020 15:58 # 5
I do not think that the pad will be finished. As HeRo1727 says in our friend, this sound is coming out in the new pad. Has it been related to discs or brake oil for 3-4 months?
08.05.2020 15:58 # 6
metin
it has to do with the disc, but I don't think it has to do with hydraulics.
Is there tremor in the pedal when the brake is applied?
08.05.2020 15:58 # 7
There is no abnormality, it is quite normal, we removed the reason from this sound, and I did not remember exactly the time after I wiped the linings with my uncle or something.
08.05.2020 15:58 # 8
metin
did you use lining spray?
08.05.2020 15:58 # 9
I did not use anything, but I do not remember exactly. When I say spray, the plugs in the engine make oxide or something, and if I squeeze them directly from rust remover sprays, would it be harmful?
08.05.2020 15:58 # 10
34sea45
The discs may be out of life or I need to erase the discs in my car because the reason is erased before I have no chance to erase it because it was erased before.
08.05.2020 15:58 # 11
the same problem is with me ... my father showed the other day to the master .. even when we pressed the brake, we realized with the commanding tremor on the steering wheel ..
08.05.2020 15:58 # 12
34sea45
forced change is required because my discs have been turning once before
08.05.2020 15:58 # 13
How long did the lathe hold your master?
you by_ 2011-08-10 13:57:22
08.05.2020 15:58 # 14
34sea45
I did not have it done, I showed the previous owner to have it made, they said that the discs cannot be reconstructed due to thinning and the discs should be changed
08.05.2020 15:58 # 15
I mean, I guess yours was thinner ... I think the thickness of my discs is good .. but I don't understand how turning works.
08.05.2020 15:58 # 16
34sea45
the brakes are making the surface slippery to the boundary, the reason for this whistling sound is very important.
08.05.2020 15:58 # 17
hmmmm .... hopefully it is not a very salty thing .. I'll go to a lathe as soon as possible ..
08.05.2020 15:58 # 18
34sea45
If you look at my mechanic saying that he is holding something like 300 lira, the exchange of 2 discs
08.05.2020 15:58 # 19
[QUOTE = 34sea45] If you look at my mechanic saying something like 300 lira, the exchange of 2 discs [/ QUOTE]
neyyyy ... so the turning of two discs is 300 tl ??? bro who knows how zero is zero now look or bored sitres i did it again ........
08.05.2020 15:58 # 20
[QUOTE = by_ersin] [QUOTE = 34sea45] if you look at my mechanic saying something like 300 lira is holding the exchange 2 discs [/ QUOTE]
Keep calm, he said about the change, he told me about zero, friend. Speak more clearly.
Page : / 2
