BIRD SOUND FROM THE ENGINE
08.05.2020 19:24 # 1
esesliemre
Hello friends, I just joined you ... First of all, greetings, I have a 307 sw 1.6 hdi diesel 2005 vehicle. Where could it be coming from? The engineer said the clutch pressure ball will change, he said he will not leave it on the road, but when that sound started to increase, I started to worry. This sound gets more pronounced when I stop my car.
08.05.2020 19:24 # 2
ahmet_bjk
Do not neglect the changeover of the timing belt, if the change is approaching or if you do not know when it has changed, always change it. If there is more to change, make sure you have a check
08.05.2020 19:24 # 3
esesliemre
Today I will take my car, let's see this time, I started to be disturbed by another master, this time, I don't think it is from the clutch pressure pad today.
08.05.2020 19:24 # 4
dagdelen34
Maybe it could be from the pressure, the bird was squeaking while I was standing with me from time to time.
08.05.2020 19:24 # 5
serdaralisan
My friend clutch ball does not sound like that, it gives buzzing straps and tackles.
08.05.2020 19:24 # 6
koss
It occurs because the gasket between the exhaust manifold and the engine loses its time and feature. It happened to me, first it was doing on the ramps, then it started to do when the engine started to load everywhere.
08.05.2020 19:24 # 7
esesliemre
Hello friends again, I went to the master, my engine chocks will also be renewed. The engine upper wedge will change, there is a piece at the bottom, the room will change. THE MOTOR IS INTERESTED IN THE BIRD SOUND, I HAVE CHANGED THE VOLTLE LOOSE, WE HAVE TO CHANGE IT. He said, maybe he said :( I am surprised by what is going to sound apart from everywhere. What should I do ...
08.05.2020 19:24 # 8
esesliemre
Current ..
08.05.2020 19:24 # 9
mistercasper
the master said it right, go get it related to flywheel
08.05.2020 19:24 # 10
esesliemre
Does the pressure pad change with the flywheel because the first master clutch pressure pad ball set said to change ..
