Bipper Turbo
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Bipper
08.05.2020 19:16 # 1
Shamil
Hello friends, in my 2012 model bipper family car, a few times in the last week, because of the fact that I used a little bit on the ramp one time, I had a smell similar to the burnt smell, once I opened the hood, the smell came from the turbo, I wonder if I have a problem with the turbo or is it normal to come due to difficulty.
08.05.2020 19:16 # 2
madblueblacksea
It is not a turbo, it can be the heat shield around the turbo, manifold and catalyst.
08.05.2020 19:16 # 3
Shamil
I will check tomorrow, INSALAH.
08.05.2020 19:16 # 4
madblueblacksea
It is sold in three pieces. The average price is 60 TL each. But if the problem is the heat shield, it's okay to change it, the catalyst is being dismantled
In the meantime, I gave this answer by assuming that the pressure pad did not heat or smell by doing a half-clutch at high speed on the straight road. Wink
madblueblackse to 2015-05-09 00:18:30
08.05.2020 19:16 # 5
Shamil
No pressure is not a brake pad, both of them had a fight, and in order to pass a little bit, I had to do more revolutions in small gear, someone had been on the ramp, the smell came after him. does it have anything to do with it?
08.05.2020 19:16 # 6
madblueblacksea
I don't think the heat shields will start to burn in a vehicle in 18000. There is a high probability of having a press pad. There is nothing because the pressure is damaged, it smells when it gets hot
08.05.2020 19:16 # 7
Shamil
Hopefully, it is as you say, that a vehicle that has always been used in calm use since the date it was purchased may have come from the pressure pad when you push it a little bit.
