BIPPER FAULT LIGHTS
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Bipper
08.05.2020 19:34 # 1
ACEDUDE
Hello friends,
I own the 2010 Model Peugeot Bipper 1.4 HDI Automatic Comfort Plus.
The vehicle is at 97,500 KM.
Today, while going up a steep hill, I had to stand at the beginning of the slope due to the oncoming vehicle driving on me. When I wanted to get up and walk again from the beginning of the slope, the vehicle could not be lifted, but I was loaded on the gas. Then the car stopped. When it stopped, DUST SMOKE appeared. When I waited for a while and opened the ignition, the car worked, I went back and continue the normal way.
When I lifted and checked the hood with the thought that there might be a problem, I noticed that the pipe I mentioned from the engine was dislodged and replaced it.
Then I checked the car's oil, in the middle of the specified lines. Then, when I lift the engine oil cap and look, I saw that there is no problem with lubrication.
Knock or sound etc. when I listen to the car. none of them were coming. But the sound in the timing belt section has increased (a sound like wind / water sound)
Then, when I opened the ignition, the warning lights came on (1st photo), when I was waiting, the warning of Airbag 1 and 2 went out, and the warning like a Stick went off (I don't know what happened) 3 warnings remained (Engine, Battery and Oil Pressure Warning). all the alerts went out and worked without any problem.
We ask for your help on the subject.
Yours sincerely, thank you.
