billet sounds from wheels |
| 08.05.2020 16:22 | # 1 |
tongucuk |
| 08.05.2020 16:22 | # 2 |
What is the size of your tires, if you write them and what is the condition of the tread
| 08.05.2020 16:22 | # 3 |
tongucuk |
could it really be related to tire sizes?
| 08.05.2020 16:22 | # 4 |
aspirinxlarge |
What I never thought of me is the sound from the left in me. The dimensions of the left back and the right behind make sense in my mind.) & Nbsp;
| 08.05.2020 16:22 | # 5 |
Kemanyak |
What the master said never made sense. There is no such problem in the 206's! First, rubber tires with different sizes of rubber, etc.)) Dude, go to another master and have the parts checked. He couldn't!
| 08.05.2020 16:22 | # 6 |
Kemanyak |
The difference in tire sizes impairs the car's braking and cornering stability. When it presses the gas, it causes it to pull in certain directions, etc. etc, but Full lap right Full lap left completely different problem. & Nbsp;
| 08.05.2020 16:22 | # 7 |
tongucuk |
I am about to eat my head, even if I tell them at the authorized service & nbsp; they do not understand, I am surprised what my napixam4 in the tire michelin right different left is not different same size all of them i love my car so much if i knew how to add pictures see my own & nbsp; but that's why I can sell anytime |
| 08.05.2020 16:22 | # 8 |
tongucuk |
If you know a master who understands peugeot very well in Istanbul & nbsp; let those who know write to him & nbsp; let me see my bidet
| 08.05.2020 16:22 | # 9 |
selling cars because of tires, burning quilts because of fleas !!!!!!!!!!
| 08.05.2020 16:22 | # 10 |
Ucyuzalti |
| 08.05.2020 16:22 | # 11 |
Instead of selling the car, find yourself a decent master, brother. P> |
| 08.05.2020 16:22 | # 12 |
aspirinxlarge |
It pulls to the right in my car, even I got used to it, it does not tire me in the bends to the right, I just leave the steering:)))))) & nbsp; Joke, you find a good master, but first a good rot etc. I am not a specialist, but those friends are connected to the computer and give clear information. & nbsp;
| 08.05.2020 16:22 | # 13 |
I had the same problem as I was turning the steering wheel to the left and right, and there was a sound of sound. Replaced bend tires and upper swing arms. These were obsolete, he said when he lifted the car on the lift. After the change was made, the sound was cut off. I think it's not about the tire, it seems like it's about ten teams ..
| 08.05.2020 16:22 | # 14 |
tongucuk |
This problem started after hitting the pavement and said that it is not related to the rod rods, they were constantly checked and now & nbsp; As the car passes through a pit from a mound, the lambor lumgur goes everywhere as it shakes & nbsp;
| 08.05.2020 16:22 | # 15 |
teacher, if it sounds like a tactical sound when taking off from the ramps or right on the left, and if this noise disappears on the straight road, it may be one of the following one of the motor lugs is damaged. > if there is a crack in the front brake discs, this will produce sound if the cause is cracked and expanded and bent. |
| 08.05.2020 16:22 | # 16 |
tongucuk |
Wouldn't it sound like a ball chirping when friends are on the normal road,
| 08.05.2020 16:22 | # 17 |
Makes humming sound into the vehicle
| 08.05.2020 16:22 | # 18 |
tongucuk |
then this is not his problem & nbsp;
| 08.05.2020 16:22 | # 19 |
look at the shock absorber pads and balls.
| 08.05.2020 16:22 | # 20 |
tongucuk |
greetings friends & nbsp; If you remember this subject, was the chassis distorted as a result of that crash? & nbsp; how & nbsp; What are the clear symptoms? |
