Benefits of Tower Tensioner
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 14:02 # 1
GokhaN
When Should The Shock Absorber Tower Tensioners Be Mounted?
Although the performance to be obtained after installation is not related to the mileage on your car, if you are a sports car owner, I recommend you to install the front strut tower tensioners at least on the first day you get your car. However, other than this somewhat optional situation, there are certain situations where shock absorber tower tensioners must be applied.
Regardless of whether the tower tensioners are front or rear, they must be applied when switching to larger wheel / tire combinations. Modifications to affect the suspension system, such as changing tougher and shorter sports springs, tougher and shorter sports shock absorbers, or to a larger diameter rim (hence thinner profile tires) ultimately increase the load on the shock absorber towers and even the entire chassis. At the end of all these applications, the stretching on the chassis will be much more than before. Here the tower tensioners to be applied after these modifications will not only support the chassis and reduce stretching, but also your steering will be more sensitive and will respond to the commands you give more quickly.
What do Shock Absorber Tower Tensioners (Front-Rear) do?
Another application frequently used in a modified car is the shock absorber tower tensioner assembly. Tower tensioners are used to join the shock absorber towers mutually into one piece.
The purpose of the tower tensioners is to minimize the stretching that occurs in the shock absorber towers, especially in hard bends. The damper towers normally flex when cornering, resulting in some traction loss (or some weakness in handling). Since the tower tensioners are designed to prevent flexions that occur in the shock absorber towers, they divide the energy by taking it from a single tower where the power is loaded and transmitting it to the other tower during cornering. This helps keep the rims parallel to the ground, which helps the tires touch the ground better. As a result, traction and handling are improved during cornering.
Alıntıdır.
08.05.2020 14:02 # 2
Emin
Did you see the benefit as someone who used Gökhan?
08.05.2020 14:02 # 3
GokhaN
You can see the obvious difference when you use it, if you have a car lying on a bend or not.
08.05.2020 14:02 # 4
kann87
I want it too.
:D
08.05.2020 14:02 # 5
CIHANGIR_DONMEZ
THROUGH KARABORSAYA IN 106
08.05.2020 14:02 # 6
[QUOTE = kann87] i want it too i dont go by car
:D
Again, you have some accessories for your car. yogi: D: DD
08.05.2020 14:02 # 7
HakanGokdemir
Not for 306 but on the market Cry
08.05.2020 14:02 # 8
GokhaN
caller finds
08.05.2020 14:02 # 9
HakanGokdemir
[QUOTE = GKN] find caller [/ QUOTE]
There is nothing to do with the caller and I am Gökhan. Although Hee becomes pale figures, Turkey had come across several mail items so ...
08.05.2020 14:02 # 10
GokhaN
[QUOTE = hakan1203] [QUOTE = GKN] finds caller [/ QUOTE]
for ebay tower tensioner link 306
He finds a caller by placing an order on ebay and putting it in the property of an importer. Or if you would like a company that brings tuning material Big smile
08.05.2020 14:02 # 11
GokhaN
:D
Tell him effecana.
ebay link
08.05.2020 14:02 # 12
HakanGokdemir
[QUOTE = GKN] [QUOTE = hakan1203] [QUOTE = GKN] finder [/ QUOTE]
Or else I was talking about in Turkey is there, then after giving up money ooooo Big smile
08.05.2020 14:02 # 13
CIHANGIR_DONMEZ
jsv's 90 lira 106 but the cemeiomus guys were talking about a round of knives what i was nervous yaw: d
08.05.2020 14:02 # 14
I did some research in Turkey for 306 but I couldn't find any. it can only come from the Netherlands in red. It costs about 140-150 TL. I want it too, but the situation is not available ... the cecol 2010-05-17 13:41:23
