Bending sensitive fog lamp
08.05.2020 17:07 # 1
omer_tarsus
Friends, can the system, which is in the new models of polo golf point vehicles and automatically lights the right or left fog lights according to the direction of the bend, can be applied to our vehicles? Is there anything like this type of module or a box?
08.05.2020 17:07 # 2
fatihgg
I think I do not want to think about the cost in the implementation :)
08.05.2020 17:07 # 3
omer_tarsus
When the American signal module was cheap or something, I thought maybe something like that came out
08.05.2020 17:07 # 4
Alicilik
Among the projects in my mind. There is a chip called Arduino. If anyone knows PIC, it's easier and changeable.
Sensor additions can be made. Gyro sensor can be done.
Cost:
arudino - 15 dollars
gyro sensor - 15 dollars
12v relay - grain 4 dollars
cables etc.
If the sensor is fixed to the vehicle, the sensor interacts and sends data with the number of forces that are not real in the turns, and this data is processed in the arduino and activates the relay. If a capacitor is used in setting one, it will be inedible.
08.05.2020 17:07 # 5
individual
I thought I would do such an application to my car.
I could put it into life if it wasn't sold.
I would put a sensor on the wheel hoods, and if it gives a signal, I would apply it as active
08.05.2020 17:07 # 6
Alicilik
I don't know how the original is, but I think it is related to the steering. It turns on when it turns the steering wheel where it stops.
What can the brake shaft be bought and adapted to the steering shaft?
08.05.2020 17:07 # 7
spearo
on vehicles with this system original & nbsp; the system operates according to the value of the angle sensor from the steering box.
steering position sensor is available in most vehicles with esp.
08.05.2020 17:07 # 8
baris5537
What does that mean when I go into the corner, let's say that the fog lamp of the flattened side is on, what does it mean for pain?
08.05.2020 17:07 # 9
Alicilik
It illuminates the blind spots in turns. & Nbsp;
08.05.2020 17:07 # 10
individual
Actually cornering lighting is something else.
after a certain speed, the lighting of the headlights in the bend is called adaptive headlight.
& nbsp;
here is the corner headlight. low-speed foglamps. and corner headlights are evident among neighborhoods or city roads.
& nbsp;
I think the most advanced headlight system is Opel's AFL system.
[TUBE] OwZ2Q2jJNEo & amp; feature = fvsr [/ TUBE]
& nbsp;
soon the headlights will be completely led.
led matrix is being developed. this headlight had 256 combinations.
[TUBE] tiSCCXaxzXc [/ TUBE] & nbsp;
08.05.2020 17:07 # 11
ledstop2009
I built this system in luxury vehicles on the 2000 model rover. It is activated when the system gives a signal and is active only when the parks are open. The most difficult part to note here is that when the quads burn, the fog should not be burnt. We also took care of it.
For those who do not know, turn the headlamp on the rotating side by turning on the fog lamp to provide a better illumination.
http://www.youtube.com/watch?v=k4ceMn2uu64
08.05.2020 17:07 # 12
individual
ledstop2009
& nbsp;
hello
I like it. but it will be super if it can go out with a little more lag when it goes out.
08.05.2020 17:07 # 13
inandugcar
We are waiting for the developments, let me know when the module is on sale ...;)
08.05.2020 17:07 # 14
satoksoz
Hi everyone,
I think the turn fog light is very useful. you get used to it after using it. I have designed a sensor mounted on the steering column for my non-feature vehicle for about 4 months. I want to give you information about the project.
Thanks to the sensor installed on the steering column, the right fog turns on when you turn the steering wheel right and the left fog light turns on when you turn the steering wheel right. .
You can set your fog to burn at the angle you want.
After turning, your fog light is 3 seconds, 4 seconds There is option to turn off after 5 seconds, 6 seconds.
Optionally, when your vehicle's parks or dipped beams are on, the system works. "# 0000CD"> You can deactivate the system at any time with one click.
12 volt is compatible with all vehicles.
http://www.youtube.com/watch?v=RJPrhL1D8Gw
< br>
08.05.2020 17:07 # 15
ahmed206
Your work is very nice, but the simpler such things are, the better for the user. For example, can anything be done without a sensor to burn wherever you signal at 1st and 2nd gears or below 30km / h?
Or is it harder to do what I said?
Regards
08.05.2020 17:07 # 16
Advantan
My c4 had this feature, the right or left fog lamp was on both when turning the steering and signaling. I think it's a sensor related situation
Advantan 2014-07-14 18:42:13
08.05.2020 17:07 # 17
samet206
In some points, I come across with me. Actually, it is not very difficult, but I can tell the driver, I do not know what its contribution is to the driver in terms of driving. I think it gives.
08.05.2020 17:07 # 18
aokaymaz
[QUOTE = samet206] I come across some points. I don't know what its contribution is to the driver in terms of driving. I think this causes a bad image.
So in my opinion, at least a straight steering wheel of 15-20 degrees When turning it to the right or left, it should be burned, or in every light not fade, without escaping from the pit, the light burns the steering wheel, the room will not be useless & nbsp;
08.05.2020 17:07 # 19
satoksoz
It does not always turn on. You can turn the steering wheel and save it at the angle you want it to be lit and adjust it. & nbsp; Reviews
08.05.2020 17:07 # 20
fætih
I guess the subject was open everywhere.
Page : / 2
