Belt Sound Traction Button
08.05.2020 19:06 # 1
GreenArmy
Hello friends, I am paying attention while going on and off, the sound of the belt is on the way, and I feel a slight drop in the shots, it does not happen frequently, it takes a short time, and the engine is hot, I changed the apricot 5-6 months ago. greenarmy 2015-02-12 20:21:16
08.05.2020 19:06 # 2
xmen
there may be looseness in the strap. did you check
08.05.2020 19:06 # 3
Efe-Pojo
what belt are you talking about which belt?
08.05.2020 19:06 # 4
GreenArmy
I am talking about v apricot, interesting, I did not handle it for two days.
08.05.2020 19:06 # 5
muro_60
Traction with v-belt has nothing to do with stretching a little bit.
08.05.2020 19:06 # 6
T€K€
And there is a self-tensioning tensioner that stretches the apricot, and a bearing at the end of the tensioner. Plus, it is work.
08.05.2020 19:06 # 7
muro_60
[QUOTE = T € K €] And there is a self-tensioning spring tensioner and a bearing at the end of the tensioner. That is, you cannot stretch the belt manually. The tensioner roller lasts for the most of the time, since the tension comes apart. money. Increased workmanship. Also, it has nothing to do with the drive. If it does not, your battery will not charge, your air conditioner will not start. Your engine will not be damaged. Let your engine be damaged ... as far as I know [/ QUOTE]
08.05.2020 19:06 # 8
monalos
I wonder if this sound comes from the v-belt, where did I find my v-belt: there is a D-belt, the room timing belt but I do it when the sound-timing is cold, or what do I think it is? in it?
08.05.2020 19:06 # 9
T€K€
It is a belt V-belt with lines in the shape of the road with the hood visible from the bottom or when viewed from the bottom of the car.
Love and respect ...
08.05.2020 19:06 # 10
T€K€
There is a tensioner bearing in the 206s. It is self-tensioned. The part name is called the tension ball.
08.05.2020 19:06 # 11
monalos
[QUOTE = T € K €] The belt is the V-belt, which has a road-shaped line with the belt that is seen when the hood is opened or when the car is viewed from the bottom.
Thanks
08.05.2020 19:06 # 12
T€K€
Can you find Monalos?
08.05.2020 19:06 # 13
GreenArmy
friends I could not write too late on the subject, sorry, the problem was solved by itself, I think it was caused by the effects of cold weather and rainy weather.
