Belt Sound? ... (resolved)
08.05.2020 16:23 # 1
xtreme59
Hello friends .. bnm 2008 model I have a 308 HDI .. They changed the alternator belt in 60000 maintenance .. After a new belt was installed, I encountered a sound similar to the belt sound in every gear shift. verudu sound ... at the same time, as the car contracted, he was in the pits .. he always thought that the belt was loose, he went to the service with the head .. the man took 2 laps .. this sound from the belt .. it solved the problem ..
3 weeks passed now the same voice started to come out of the car again .. I have no way to go to the service nearby .. I wonder what is this process .. what did this friend do? If anyone has information, can they share .. thanks in advance ..
xtreme59 2012-02-05 14:29:28
08.05.2020 16:23 # 2
Ucyuzalti
If you examine the form, there is a lot of information about apricot sound, because a friend became friends with this sound "Big they will help & nbsp;
08.05.2020 16:23 # 3
xtreme59
the problem has been solved ...
I write that if you happen to you ... what we thought from the beginning was the sound of a piece of rubber that was inserted between the chassis and the pipes to prevent the pipes coming from the fuel tank from touching the chassis. .. 2-3 drops of Japanese glue solved the job ..
If you have a sound like bnm, you can either have a look .. :)
08.05.2020 16:23 # 4
djchaos
glad that the problem is solved, thanks for sharing the solution with us
