belt sound from my partner
08.05.2020 16:35 # 1
aopena
When my friends move the steering wheel slightly in my car, there are small sounds, the belt sounds, and when I get into the hall, what comes the problem? How can it be corrected?
08.05.2020 16:35 # 2
gozem
If it comes while moving the steering wheel, it is most likely the steering pump.
It can cost a lot. Friends who are more knowledgeable about this will help .. get back.
08.05.2020 16:35 # 3
Cmoss06
There may be jam in the hydraulic pump. Check the hydraulic pump oil level. If the sound is clicking, the charging belt can make the tensioning ball. Hopefully it will recover.
08.05.2020 16:35 # 4
nightfly
I also had a local belt attached when the belt was working when I first worked. When I changed the coast, I learned that the ball bearing of the belt was broken, and I changed it now. let me see the problem may be the same & nbsp;
08.05.2020 16:35 # 5
aspirinxlarge
Friends, when the power steering runs out, does it harden? so what happens when fat is low? Can we go get this oil and put it ourselves? & nbsp;
08.05.2020 16:35 # 6
Cmoss06
When the oil runs out, it makes a noise when it spins, and if it decreases, add or add oil.
08.05.2020 16:35 # 7
aspirinxlarge
I wonder which brand and which number is used for Pejo 206 petrol model, & nbsp; I think I'll take this. & nbsp; The steering has become a little stiff. & Nbsp; What do you think is the most qualified? & nbsp;
08.05.2020 16:35 # 8
djchaos
It is normal that there is a slight sound when you turn the steering wheel, it is the sound of the pump.
08.05.2020 16:35 # 9
Cmoss06
You can get branded oils, but no crossing from tota "Thumbs
