Beep While Running
08.05.2020 15:26 # 1
revolutionary26
Friends, it's been 1 month since I bought the vehicle. This is one of the points that I cannot fully solve. I turn on the ignition before I start the car, I wait for the lights on the indicator to go out, but sometimes when I show the oil level, I hear a beep and it stops when I start the car soon. I look at the screen and it doesn't write anything. the key battery may be running out of power?
thanks.
revolutionary26 2011-05-16 20:56:43
08.05.2020 15:26 # 2
metin
Along with the sound warning, the problem should be written on the screen.
you will also receive the "remote control battery low" alert if the control battery is running out.
08.05.2020 15:26 # 3
azdek
It's not about the battery, he was doing it for me and then he cut it, then he started, then he took it to normal maintenance, then he might have cut off his dirt or something that might have started his work properly (it may be time for maintenance).
08.05.2020 15:26 # 4
If the gas light is on, the air beeps every time it is below -3 degrees.
08.05.2020 15:26 # 5
revolutionary26
azdek: maintenance is new. The next maintenance shows the Km as 29650.
mustafafakirli: gasoline light is not on. the tank is full of a quarter and generally the air is between 9-11 degrees
08.05.2020 15:26 # 6
metin
[QUOTE = Mustafakirli] If the gas light is on, it will beep every time the air is below -3 degrees. [/ QUOTE]
Brother says there is only sound. I couldn't understand.
08.05.2020 15:26 # 7
mimitt
the maintenance meter of the vehicle may not have been reset, so you may hear a beep.
08.05.2020 15:26 # 8
revolutionary26
[QUOTE = mimitt] the maintenance counter of the vehicle may not be reset, so you may hear a beep. [/ QUOTE]
After my teacher changed the oil of the vehicle, the master reset. now it shows 29650 km. before the oil showed 2600.
08.05.2020 15:26 # 9
goktug
Look at the water is running out.
08.05.2020 15:26 # 10
revolutionary26
[QUOTE = göktuğ] look at the water is running out. [/ QUOTE]
my teacher is full of water. only when the engine is overheated when the temperature is around 90, there is a slight smell of antifreeze inside.
08.05.2020 15:26 # 11
goktug
the smell of that antifreeze is caused by the excess water.
08.05.2020 15:26 # 12
revolutionary26
[QUOTE = göktuğ] that antifreeze smell is due to excess water. [/ QUOTE]
Thank you, I was suspecting that there was a leak. I didn't see the water running out.
How are we going to drain the water?
