Beep beep when opening cd player
08.05.2020 14:11 # 1
t@lip
Hello friends,
When using my 2007 model 207 car's cd player, the beep beeps at 1 second intervals. What is the reason and how can I handle it? I would be glad if anyone who shares the information. Wishes without accident, faultless and pleasant driving.
08.05.2020 14:11 # 2
peugeotefe
the tape must have reset itself, it must be connected to the peugeot planet tester and the vehicle's chassis number must be coded to the tape
08.05.2020 14:11 # 3
t@lip
I guessed there was a problem with the code efe, thanks for your answer. Is there anything that needs to be done, for example, in the battery change, so that the tape does not reset itself, or did you disassemble the pole head, do you absolutely reset it? The vehicle goes into economic mode in 4-5 minutes. I decided to follow the battery for a while and change it if necessary. So if necessary, I think I'll go to the service after I replace the battery.
08.05.2020 14:11 # 4
peugeotefe
Replace the battery, I think it has nothing to do with disassembling. Power drops below 12 volts.
08.05.2020 14:11 # 5
t@lip
I just talked to a private service in Ankara, they said they told you and we recorded the chassis number for 30TL on the device, Efe said. Let me investigate a little more, if not, I will go get it now. Thank you very much for your help. And without forgetting, CD is inserted from time to time. I wonder if I squeeze the WD40 into my cd player. Talip_019 2010-03-16 16:00:09
08.05.2020 14:11 # 6
peugeotefe
I guess there is no place that makes it lower than the price.
08.05.2020 14:11 # 7
hasimayaz
http://www.peugeotturkey.com/nasil_yapilir.asp?makaleıd=64
08.05.2020 14:11 # 8
t@lip
I learned a lot from this site, one of the friends says what to do, the other says how to do it, thank you guys. Talip_019 2010-03-17 09:54:47
