Battery trouble.
08.05.2020 20:36 # 1
aykutbayram1996
Right friends of my car's contact broke down, I swapped, the complete vehicle was uneventful, I came home at night, I turned on the ignition, the battery was discharged 1 2 lamps burned, I hit it very rarely, did not work, then we worked with the reinforcement, shortly, the contact is switched on, if it is left, the battery is over, then the battery runs out of it, if you have the help of the contact, then we have the help of the contact. it was.
08.05.2020 20:36 # 2
uzunca961
Understandably, if electricity stays on, buddy. Check things that are not working normally when the ignition is off.
08.05.2020 20:36 # 3
[QUOTE = Uzunca961] Understandable buddy if electricity stays on. Normally, check the things that are not working when the ignition is off.
+1
08.05.2020 20:36 # 4
aykutbayram1996
There is a plumbing in the vehicle, the lamp's lamp is on.
