Battery system relationship
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Other Brands
08.05.2020 21:10 # 1
Diver28
Hello friends, I want to share a problem I had in my car. When I was driving on the road, the car gave us an acceleration situation when I pressed the gas to not downshift at the ideal speeds. I did the same thing as he said he asked me to remove the battery pole head and put it on after 5 minutes. I went on my way as if nothing had happened. 1.4 16v semi-automatic sensodrive. If I wonder if there is a problem with the action, there is not always a problem with the gear changes or if I do not understand what is the relationship with the battery? Thank you very much for your valuable comments.
08.05.2020 21:10 # 2
Hodja probably has an electrical problem oxidation - disconnection in cables etc. If it is short-circuited, the vehicle has been protected. When the battery was disconnected from the pole, the system was restored as if there was no problem since it automatically resets. I checked the voltage values of the vehicle both in the position and on the load (air conditioner - headlights etc.).
08.05.2020 21:10 # 3
Diver28
Thank you they looked at the battery value 88% output. They did not connect to the computer and made a detection.
08.05.2020 21:10 # 4
So, did my teacher look with the original device or did they look with a universal diagnostic tool?
08.05.2020 21:10 # 5
Diver28
I removed the original tape of the vehicle and had an mp3 player installed 1.5 months ago, I wonder if they tied a cable wrong.
08.05.2020 21:10 # 6
My teacher may even burn the vehicle's electrical installation due to the wrong connection. an important issue, although it seems simple. they make general cut cables with electrical tape, but I always recommend using heat shrink tubing, especially in new generation vehicles (with electronic system). & nbsp;
08.05.2020 21:10 # 7
Diver28
Thank you very much, I suspect me, I will share it with an electrician tomorrow.
08.05.2020 21:10 # 8
Diver28
[QUOTE = Diver28] Thank you very much, I suspect that I will take it to an electrician tomorrow. I hope the problem will be solved.
