Battery replacement
08.05.2020 17:28 # 1
ahmet_bjk
Hello guys ...
& nbsp;
I'm thinking of changing the battery soon. & nbsp;
& nbsp;
& nbsp; 2009 model 1.6 HDI How many & nbsp; amp batteries are required? & nbsp; What are the benefits or harms of an amperage battery rated higher than this ampere?
08.05.2020 17:28 # 2
baroff
You can look at the amps above the previous battery, or if there is a booklet of the vehicle it will write there.
08.05.2020 17:28 # 3
SDYMZ
If I don't recall 308 1.6 hdi wrong, there are 70 ah batteries
08.05.2020 17:28 # 4
If your vehicle has extra equipment such as a music system, you should purchase a higher-amp battery. If there is no, it is sufficient to take the standard whatever it is. However, if you take the high, there is no harm. Notice that after a value, the size of the battery is as well, and you cannot fit it. Dimensions are also important.
08.05.2020 17:28 # 5
206 ersan
Well, when friends disassemble the battery, it is necessary to start with the minus pole or the positive pole first.
08.05.2020 17:28 # 6
[QUOTE = 206 ersan] well, when friends disassemble the battery, it is necessary to start with minus pole or plus pole. As far as I know the disassembly sequence is damaging the brains, my fiat uno ignition brain was broken in another vehicle from the wrong disassembly sequence [/ QUOTE]
When installing
first + then -
when removing
, I know the opposite - first + then +. My knowledge of the Taa driving school is this "Approve"
08.05.2020 17:28 # 7
206 ersan
I do not remember when I taught something like this in the driving course but then my 3 previous vehicle was fiat uno 2001 model when I was going on the road constantly, the stop code was broken from the battery sequence.
08.05.2020 17:28 # 8
[QUOTE = 206 ersan] Well, when friends disassemble the battery, it is necessary to start with minus pole or plus pole. As far as I know the dismantling order is damaging the brains, my fiat uno ignition brain was broken in another vehicle from the wrong disassembly sequence [/ QUOTE]
I have shared the exact rule of inserting the battery connection in the link below.
the http://forum.peugeotturkey.com/forum_posts.asp?tıd=20338&title=aku-kutup-baslarini-sokerken-3-dakika-kural
Koliva 2013-04-01 05:41:46
