battery problem
08.05.2020 16:30 # 1
lkr_yldz
friends, how many amps of this battery did 2 make me think i am changing myself
08.05.2020 16:30 # 2
lkr_yldz
If I was able to upload the following image in the bidet :(
08.05.2020 16:30 # 3
lkr_yldz
http://imageupload.org/?d=B581B03A1
08.05.2020 16:30 # 4
tongucuk
the battery is important.
08.05.2020 16:30 # 5
lkr_yldz
I don't know how many amperes I think so
08.05.2020 16:30 # 6
Do you have extra equipment in your vehicle? Or a product different from the original hardware?
08.05.2020 16:30 # 7
yavuz25
dry battery is 60 if I am not guessing wrong. "Wink" I put it in front of the door in the first butterfly. The battery is very very important. "Wink" < edited> yavuz25 2012-01-01 16:22:16
08.05.2020 16:30 # 8
06OzGuR06
Varta is not a bad battery, but why did it happen? "Ermm"
08.05.2020 16:30 # 9
yavuz25
[QUOTE = 06ÖZGÜR06] Varta is not a bad battery, but why is it so? "Ermm" [/ QUOTE]
& nbsp;
I wonder how many years
08.05.2020 16:30 # 10
06OzGuR06
[QUOTE = yavuz25] [QUOTE = 06ÖZGÜR06] Varta is not a bad battery, but why did it happen? "Ermm" [ / QUOTE]
5-6 years old battery has already expired.
When buying the battery, you should definitely look at the production date and get the warranty certificate. & nbsp; Sometimes crooks can install outdated batteries. Or some of them are fake. "Shocked"
06ÖzGüR06 2012-01-01 16:37:28
08.05.2020 16:30 # 11
yavuz25
[QUOTE = 06ÖZGÜR06] [QUOTE = yavuz25] [QUOTE = 06ÖGGR06] Varta is not a bad battery, but why is it so? "Ermm" [/ QUOTE]
how many years
5-6 years old battery has already expired. "Smile"
When buying the battery, you should definitely look at the production date and get the warranty certificate. "Smile" & nbsp; Sometimes crooks can install outdated batteries. Or some of them are fake. "Shocked"
& nbsp;
"Thumbs
08.05.2020 16:30 # 12
lkr_yldz
[QUOTE = koliva] Do you have extra equipment in your vehicle? Or a product different from the original hardware? [/ QUOTE]
as an extra, there is music installation, there is a bidet foot lighting, nothing else but my installation is not such a powerful thing
08.05.2020 16:30 # 13
lkr_yldz
[QUOTE = yavuz25] [QUOTE = 06ÖZGÜR06] Varta is not a bad battery but why did it happen? "Ermm" [ / QUOTE]
& nbsp; the car was 6 years old, I knew it was a new battery, but I think it's the original factory battery
08.05.2020 16:30 # 14
lkr_yldz
[QUOTE = yavuz25] dry battery is 60 if I guess wrong. "Wink" I would put it in front of the door in the first butterfly it threw. The battery is very very important. "Wink" [/ QUOTE]
& nbsp; does not write amps anywhere on the left and right of the battery. Happy brand's site shows how many batteries are installed when you enter the brand model of the vehicle. According to there, I had to install a 12v 50 amp battery
08.05.2020 16:30 # 15
yavuz25
I have two batteries that I have seen & nbsp; I have never seen one of 60 and one of 72 is. "Smile" In my opinion, find out how many amps should be installed from the user manual or other 206 users. But my idea would be 60 for your car. "Wink"
08.05.2020 16:30 # 16
yavuz25
[QUOTE = lkr_yldz] [QUOTE = yavuz25] [QUOTE = 06ÖGGR06] Varta is not a bad battery, but why is it? "Ermm" [/ QUOTE]
how many years I wonder
& nbsp; the car was 6 years old I knew it as a new battery, but I think the original factory battery < / div> [/ QUOTE]
I guess so because it is a dry battery. So it has already expired. "Wink" You pass it.
08.05.2020 16:30 # 17
yavuz25
Now looking at our car also says 50 amps. "Ermm"
08.05.2020 16:30 # 18
[QUOTE = lkr_yldz] does not write amps anywhere on the left and right of the battery. Happy brand's site shows how many batteries are installed when you enter the brand model of the vehicle. According to there, I had to install a 12v 50 amp battery [/ QUOTE] The numbers on the picture show how many amps are already. The value that writes 640 is the crank value on the cold. You can see how many amps are in the table below. I think you can measure whether your vehicle is pulling current or not. According to what I feel (), your car has a leg. Battery Capacity [Ah] Cold Cranking Amps (CCA), EN [A] 41 360 45 300 45 400 53 470 56 480 70 640 88 740 90 720
08.05.2020 16:30 # 19
yavuz25
Happy battery & nbsp; battery needs to be installed & nbsp; 50 amp, my brother says. "Ermm" yavuz25 < editDate> 2012-01-01 18:12:38
08.05.2020 16:30 # 20
lkr_yldz
[QUOTE = koliva] [QUOTE = lkr_yldz] does not write amps anywhere on the left or right side of the battery. Happy brand's site shows how many batteries are installed when you enter the brand model of the vehicle. According to there, I had to install a 12v 50 amp battery [/ QUOTE] The numbers on the picture show how many amps are already. The value that writes 640 is the crank value on the cold. You can see how many amps are in the table below. I think you can measure whether your vehicle is pulling current or not. According to what I feel (), your car has a leg. Battery Capacity [Ah] Cold Cranking Amps (CCA), EN [A] 41 360 45 300 45 400 53 470 56 480 70 640 88 740 90 720 [/ QUOTE] 70's battery is too much, I am confused thoroughly 50 or 70 mi
Page : / 3
