battery light on the indicator
08.05.2020 15:17 # 1
serkan106XR
When I said that it was all right, my car started to have problems again. In the evening, I got off the 400 km long road, there was heavy rain outside, after I had gone 100 km after a bus, the car suddenly began to shake. I pulled a little to the right, stopped a little, I tried a few times for half an hour, the car couldn't even get up at 1 gear. I pulled to the right again, I tried again in half an hour, I proceeded in a normal way. After 5 hours after the rain started, the car did the same thing again. I pulled to the right, I slept for half an hour, the car was back to normal again (all this is around 2-3 at night. I have no chance) then rain stopped and the same problem did not happen until Istanbul. But I couldn't see my way along the way. Did the headlights get muddy? I said, but it was also normal. When I entered TEM, I even did 150-160 speed, there was no problem. Just as the e-5 was overnight, the battery flashed on the display. I took the charge of the phone, turned off the tape. I almost never see the way. I went down and looked, the headlights are on but they are very thin. Then I parked in front of the house, I looked today, the battery indicator light is still on, the headlights are still on. what could be the problem with the car?
08.05.2020 15:17 # 2
Burak07
It may be a leak, our biggest problem is that this car electronics fails immediately. I recommend you to look at the poles.
08.05.2020 15:17 # 3
helot
I think it was caused by the charger, it was what happened to my friend.
08.05.2020 15:17 # 4
serkan106XR
Let's take it to a service tomorrow. After seeing the Balıkesir plate, the standing piles are now on the ground like Istanbul :(
08.05.2020 15:17 # 5
helot
I am sure there are friends who will help you in Istanbul :)
08.05.2020 15:17 # 6
08.05.2020 15:17 # 7
eneslan
[QUOTE = serkan106XR] we'll take you to a service tomorrow. After seeing the Balıkesir plate, the standing piles are now on the ground like Istanbul: ([/ QUOTE]
I sent a private message, my friend Serkan
08.05.2020 15:17 # 8
Serhun
Friends have written the problems, the past is likely to be from the converter alternator
08.05.2020 15:17 # 9
hhuzun
There may be a break in the connections of the lead plates inside the battery, so check the battery.
08.05.2020 15:17 # 10
serkan106XR
I took it to a service right next to the house. battery voltage was 11.70. We will disassemble the charger. If repair is possible, it will not be lower than 300. if it needs to be changed, it will find 600-700 TL, the whole process takes 1 day. I called my own electrician because he was so expensive, he said, right away. Then he found a master from Alibeyköy on the phone, so I took the car there, so I did not stay on the road, and he repaired it in 1 hour. there is no trust in this nation of repairers.
08.05.2020 15:17 # 11
Serhun
I think the price of alternator coals diodes and bearings including labor. Get well use it.
You are right about the masters. I went to work with my car to go to Istanbul. we took the vehicle together with the relative of my friend at our workplace to the electrician. The electrician said, bring me an alternator. He wanted 50 TL to dismantle my place. I came home saying I don't have a job, the problem came out from the pole because the chassis cable was loose, I solved it myself.
08.05.2020 15:17 # 12
serkan106XR
Get well, you should get over it cheaply. but I think it was difficult to disassemble the alternator, everywhere I went was close to the difficulty of removing it
08.05.2020 15:17 # 13
Serhun
I got rid of electrician and biker without hitting me yes. You know I don't like exaggeration, I was dealing with cars before I said water Sırıtma This is a strange place, more litters per square meter than in Istanbul. But for the first time, I came across the electrician who said remove the alternator, all the auto electricians I know will remove the starter motor and the alternator by themselves. It was easy on my vehicle, the place remains at the top. If it is normally a working area, the coals can be changed on top without removing the alternator. When I came to Istanbul, I took 10 minutes, I found that it was because they did not fix the battery, because it was loosening the pole from shaking. The biggest factor in making the service incident a self-service is the mechanics with this type of mentality.
08.05.2020 15:17 # 14
sdts
Look at the diodes of the dynamo, probably there
08.05.2020 15:17 # 15
serkan106XR
I'm sick of it now. The car stopped for 4 days only. Today the damn battery light came on again, and that strange sound from the charging dynamo started again, I am sick of it, would a person go to the industry 3-4 times a month, and if I bought a car, I would have paid my installments every month. .
08.05.2020 15:17 # 16
ugurdilli
My brother started the same problem, can you please give your phone with the address of the master in Alibeykoy?
08.05.2020 15:17 # 17
mertcancmrt
In the evening, the battery lamp burned and I showed it to the master this morning.
08.05.2020 15:17 # 18
[QUOTE = mertcancmrt] In the evening, the battery lamp burned, I showed it to the master this morning, he said he does not charge the dynamos.
it is likely that the coordinator will need to change and the teacher must be disassembled and checked. The price came as normal.
08.05.2020 15:17 # 19
mertcancmrt
Okay thank you
08.05.2020 15:17 # 20
madblueblacksea
150 felt like a little flying. !! I disassembled my dynamo to 50 TL and changed the rings and replaced it.
Page : / 2
