Battery lamp that goes out after 206- 3000 cycles
08.05.2020 20:52 # 1
bilo131
Hello friends. (My Car 2000 Model Rolland Garros)
While coming to Istanbul on the Ankara-Istanbul highway today, I noticed that the battery lamp was on. While cruising, I pressed the clutch to root the gas and the lamp went out. Then I used a low speed car for traffic. After 5 minutes, the lamp came on again, but not so alive, but faded. When the traffic turned on, I came to 1-2-3-4-5 gear at 2500 rpm, the lamp was still on. I gradually increased the speed, while the 3000i passed slowly, the light started to blink when it became 3500. I stopped the car in a convenient place. I had an electronic measuring device with me. I stopped the car and measured the voltage. It showed 12.5 v. Then I ran it and checked again it showed 14.3. I replaced the battery 3 months ago 12v 60A. There has been no problem so far.
I think I would be glad if friends with guesses help where the problem might be. Good forums.
08.05.2020 20:52 # 2
onlycihan
either your brake hydrolysis is decreasing or sometimes it is because of contact contact that I have. when the battery lamp is on, move the ignition slightly (do not turn over).
08.05.2020 20:52 # 3
bilo131
I read the contact event in the forum, I will try. But I didn't understand the brake fluid, why would he do it?
08.05.2020 20:52 # 4
talip206
It can be from contact. Play a little bit when the light turns on. or the charger may not be producing enough power. Last chance your mind is troubled. Even if it is new, it can sometimes be a problem with the battery.
08.05.2020 20:52 # 5
onlycihan
[QUOTE = bilo131] I have read the contact event in the forum, I will try. But I did not understand the brake fluid, why should he do it [/ QUOTE] sorry I mixed it with the stop lamp, the hydraulic event is likely to be caused by the host the onlycih 2018-05-06 21:03:22
08.05.2020 20:52 # 6
Beyinci_Ugur
the alternator is faulty. If you go to the autoelectricity before the business grows, it is solved by repair
08.05.2020 20:52 # 7
bilo131
I checked the contact event, but there was no improvement. Today, the lamp never went out. I brought the cycle to 5-6 thousand, it was extinguished, but when I released the gas, it burned again. I now suspect the charger. I'll stop by auto electrician tomorrow. If my problem is solved, I will give Information.
08.05.2020 20:52 # 8
bilo131
yes friends again I am serving my sentence and ignorance LOL I still haven't gone to the industry and the lamp is still on when I came home yesterday, besides, as Eksta, the headlights were very steady, the instrument panel lights started to go out. LOLBig smile Finally, when I came to the front of the house, I hardly closed the windows. And now I'm starting the car and the battery is over LOLLOL let's see I will find a solution now so the problem was on the charger
