Battery lamp is on
08.05.2020 20:57 # 1
prens3574
When the 307 is stopped, the battery lamp lights up for 3 seconds. It is lightly spoiled for the first time. As I said, there is no drop when the headlights are turned on.
08.05.2020 20:57 # 2
GokhaN
there may be a leak in a place with the contact means that it is not closing in the leak. Find a good electrician and check it out. I think Battery - Starter and Spark Plug control is necessary.
08.05.2020 20:57 # 3
prens3574
thank you let me see what I will write out the result. Have a good Friday.
08.05.2020 20:57 # 4
prens3574
Does not charge the battery lamp on the move when it is on my mind, does not warn it occasionally or directly. I came in the evening, worked unconscious, we visited for 10 minutes, we did not even remove the windows.
08.05.2020 20:57 # 5
Selcuk55
I guess the battery is out of date with the sister dynamo, check the battery charge
08.05.2020 20:57 # 6
prens3574
My mind is that the last week of the timing circulation and the engine water has changed, I wonder if the alternator belt is likely to be loose.
08.05.2020 20:57 # 7
Selcuk55
If the pulley turns, it means no problem
08.05.2020 20:57 # 8
prens3574
Yes, friends, I was going to set off for a long time in the morning. There wasn't even a click.
08.05.2020 20:57 # 9
GokhaN
[QUOTE = prince3574] yes, friends I would go long in the morning. There is no click in the starter. Doors did not open automatically.
we guessed correctly then the problem is on the battery Smile
