Battery lamp
08.05.2020 15:14 # 1
insomnia
Dear friends, when connecting my 306 sound system, when the ignition switch is not turned on, the power does not go to the tape so that the ignition does not get triggered and to prevent any battery from running out, I connected the ignition to the A mode. so I would like to learn to ask if there is any damage to the vehicle while in this position.
insomnia 2011-04-08 22:05:39
08.05.2020 15:14 # 2
106_arts
I had it installed in the same way, but the battery lamp was not lit, it could be the wrong link.
08.05.2020 15:14 # 3
insomnia
[QUOTE = 106_arts] I got it the same way, but the battery lamp was not lit, it could be the wrong link. It should not be burned.
08.05.2020 15:14 # 4
It is true that it burns with certainty. is burning in the same way in me. For the tape to work, it is necessary to turn the key one step. & nbsp; in this case, I don't think anything will happen. I waited so hungry too. It is necessary to set the contact to this level for the operation of all electrical components. but if the electricity is taken out of the contact, the tape runs without interruption ...
08.05.2020 15:14 # 5
[QUOTE = insomnia] Dear friends, when connecting my 306 sound system, when the ignition switch is not turned on, the tape will not energize so I have not connected the amplifier and prevented any battery from running out. ignition or circuit systems etc. so in any way I would like to learn to ask if there is any damage to the vehicle in this position
In my car, the tape is connected in the same way and I listened to it for a long time, but there is no amplifier and subwoofer.
The amplifier and subwoofer systems draw more electricity. If you listen to the tape for a long time in this position, your battery will be weak.
It is good that the tape system is connected to the ignition but I do not recommend you to listen to the tape for a long time without starting the vehicle.
08.05.2020 15:14 # 6
insomnia
The tape was connected in my vehicle in the same way and I listened to it for a long time. no amplifier and subwoofer.
Amplifier and subwoofer systems draw more electricity. If you listen to the tape for a long time in this position, your battery will be weak.
It is good that the tape system is connected to the ignition, but I do not recommend you to listen to the tape for a long time without starting the vehicle. ]
alpina S12 double coil, sucking exactly like the vampire
08.05.2020 15:14 # 7
insomnia
It is true that [QUOTE = cecoli] will definitely burn. is burning in the same way in me. For the tape to work, it is necessary to turn the key one step. & nbsp; in this case, I don't think anything will happen. I waited so hungry too. It is necessary to set the contact to this level for the operation of all electrical components. but if non-contact electricity is taken, the tape works without interruption ... [/ QUOTE]
thanks cecoli master, you can control all the electrical systems exactly as you turn it to a level. >
08.05.2020 15:14 # 8
@ insomniia = & nbsp; I think & nbsp; that kind of system should be activated when the contact is open. opening the contact means making the engine running ... but we are not going to open the contact.
08.05.2020 15:14 # 9
insomnia
[QUOTE = cecoli] @ insomniia = & nbsp; I think & nbsp; that kind of systems should be activated when the contact is open. to open the contact means to make the engine run ... but we do not open the contact in that case. [/ QUOTE]
I agree, just wanted to make sure, thank you for your support
