battery is constantly discharging
08.05.2020 17:02 # 1
alp2525
Two-year pearl battery on my vehicle. When I do not move the car for 1-2 days, the battery is weakened. The last one I took to the master, was there a leak in order to see if there was a leak, the master battery + pole head was removed, and the battery was touched to the pole.
08.05.2020 17:02 # 2
alp2525
The battery of the vehicle lights up when I burn it for 1 minute, when it is weak, the stpo and abs light flashes 3 times after starting the vehicle, after moving the vehicle for 15-20 minutes, when I turn the ignition, there is no problem, it works directly and the stop and abs light are not lit. Is there a leak in my car or is it not connected to the contact with double din piranha navigation attached in my car?
08.05.2020 17:02 # 3
mev347
This problem does not sound foreign to me. I have a navitech tape. When I connect it, my car's battery was discharged in 2 days. I found the car to contact. I just bought the battery and I overhauled it because of this.
08.05.2020 17:02 # 4
volkan22
I think you have tried to follow another battery before trying to distribute the vehicle ...
08.05.2020 17:02 # 5
cerci07
the battery is dead
08.05.2020 17:02 # 6
soner09
I had the same problem, I bought zero, I changed the charging dynamo to the point, there was no problem.
08.05.2020 17:02 # 7
sert-ac
old, my car came to print problem dynamo
