Battery drain problem in the vehicle
08.05.2020 20:48 # 1
selcukyesiltas
Hello to everyone
My car 1.6 hdi executive vehicle has a battery run-out problem. they gonderiyor.
08.05.2020 20:48 # 2
talip206
Either there is a leak somewhere or the charging dynamo cannot fulfill its duty. Or even if the battery is new, it fails immediately as a fabrication. I think there is no other possibility.
If you can find the battery, try another battery entrusted, try a few days
08.05.2020 20:48 # 3
ggitaristt
1-If there is an external tape recorder, remove the head and flash memory.
2-The charge may be 14.1 V, but the battery may be faulty and not charging.
3-It is necessary to measure for a long time how much current draws, what does it eat in charge?
A zero battery is a situation that happens more than expected.
08.05.2020 20:48 # 4
maximusti
[QUOTE = ggitaristt]
+1, 3 times in a row, zero battery was broken.
08.05.2020 20:48 # 5
HasGur
[QUOTE = selcukyesiltas] Hello everyone
My car 1.6 hdi executive vehicle has a battery run-out problem. they send. [/ QUOTE]
Battery discharges in 2 days and in the vehicle;
if there is no leak,
if the charge is normal,
If the fridge connected to the 12/230 ineverter does not cool the drinks while heading in the parked vehicle or if the headlights are not used to illuminate the grill, the only option left is BATTERY.
08.05.2020 20:48 # 6
selcukyesiltas
[QUOTE = ggitaristt] 1-If there is an external tape recorder, remove the head and flash memory.
No external components are installed in the vehicle 3. When the zero battery is plugged in, the leak does not constantly discharge the battery immediately.
08.05.2020 20:48 # 7
Pug206sw
I wonder if all three batteries were happy? If so, it may even be from it.
08.05.2020 20:48 # 8
selcukyesiltas
Happy pearl power
08.05.2020 20:48 # 9
serdarr4
Have your battery measured. Even new batteries can fail immediately. When making the battery measurement master, it connects the avometer to your battery and the avometer shows approximately 12v. The car is not started. In the meantime, if it is observed that the value of the avometer drops visibly, your battery is bad. You need to buy a new one.
Another point that comes to my mind is that the lamps in the button at the bottom of the front digital panel of my 407 vehicle are constantly on and off.
01.03.2021 00:43 # 10
Denizzzzz
Hello. Why is the problem caused, and I have the same problem, the battery has changed, the leak check has been done, the problem still continues.
