battery control help .. |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 15:06 | # 1 |
| 08.05.2020 15:06 | # 2 |
Those who come to you with the remote control battery low alert have nothing to do with my mind. When the radio is on, if the battery drops below a certain level, it will already switch to eco-mode. I think your problem is either from the battery or the mechanism to charge the battery. There is an alternator at the beginning of this mechanism and it may be defective because the battery that is not charged correctly may not be able to start and start the starter during the first start. Besides this, there may be a problem with the belt. In short, it is useful to have the battery checked first and then the charging mechanism. |
| 08.05.2020 15:06 | # 3 |
I am telling you the steps you will do. When you open the 1st stage contact, there is no sound when you start the ignition. 2. Turn on the ignition. means you are finished check cables, best regards .stallone 306 GTI-6
