Battery Charging Problem
08.05.2020 18:26 # 1
smehmetyildirim
Hello friends. I bought the battery about 5-6 months ago, my car did not work for 2-3 days, even though the weather was not so cold, it finished the battery. We reinforced it and started the car for about 40 minutes. the battery is not charged. there is nothing wrong with the indicators, battery charge light or something. There is a sound system in the vehicle. I would be glad if you could help. I smehmetyild 2014-04-10 00:12:31
08.05.2020 18:26 # 2
get well soon ... do not turn on music / headlight for 1 hour after reinforcing. Then make sure that all the lamps, including the trunk light, are turned off when closing the vehicle. Do not operate the vehicle for 1-2 days after turning off the vehicle and making sure all the lights have gone out. Then, when you start the car, if the car does not work, replace the battery first. Repeat the same operations on a fully charged battery. If the problem is caused by the battery, the problem will disappear. If your vehicle still has the same problem, there is a leak somewhere. A good electrician should check the car
08.05.2020 18:26 # 3
smehmetyildirim
OK, teacher, I will write the result as I say thank you. I smehmetyild 2014-04-10 00:26:05
08.05.2020 18:26 # 4
Wink
08.05.2020 18:26 # 5
kuscu38
Look at the battery which color is not green if the problem is not from the battery. If the battery is green, measure the battery in any e-boiler. kuscu38 2014-04-10 09:22:36
