Battery Attenuation in Cold Weather
08.05.2020 16:37 # 1
aspirinxlarge
Guys, my 206`s resist not working in cold weather. & Nbsp; Anfirir etc. Everything is complete, but the battery seems bad. I can run the same vehicle very comfortably when the weather is hot. What can I do to care for the battery. & Nbsp;
08.05.2020 16:37 # 2
djchaos
recharge the battery, add pure water, it is not difficult to work in cold weather, especially if your battery is weak or buy a new battery
08.05.2020 16:37 # 3
check the water levels of your battery .. besides this, you can use grease to prevent the terminals from oxidizing.
08.05.2020 16:37 # 4
aspirinxlarge
God, I knew that there were no such events in new types of batteries. & Nbsp; Is there a Duracell battery:)) & nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & nbsp; kidding & nbsp; :) & Nbsp;
08.05.2020 16:37 # 5
aspirinxlarge
I will look at adding water, it seems that we will hit again in the morning, you are coming to the snow or snow. & Nbsp; I go by bus now. & nbsp; :( & nbsp;
08.05.2020 16:37 # 6
[QUOTE = aspirinxlarge] I will look at adding water, apparently we will hit it again in the morning, you are coming to the sun or snow. & Nbsp; I go by bus now. & nbsp; :( & nbsp; [/ QUOTE]
definitely use pure water .. & nbsp;
08.05.2020 16:37 # 7
aspirinxlarge
[QUOTE = cigdemilker] [QUOTE = aspirinxlarge] I will look at adding water, apparently we will hit it again in the morning, it is a bad or snow coming. & Nbsp; I go by bus now. & nbsp; :( & nbsp; [/ QUOTE]
use distilled water definitely .. & nbsp;
Okay, I'll see sometime tomorrow. I'll take the issue. & nbsp;
08.05.2020 16:37 # 8
By the way, when I said pure water, it came to my mind, of course, it is a bit ridiculous in the winter, but when you need pure water one day, the air conditioner is liquid water that flows out where you are, if you need pure water ... for your battery .. & nbsp; has pure water & nbsp; "smileys / smiley36.gif" border = "0" alt = "LOL" title = "LOL" /> & nbsp; after entering the money, our nation is in search of all kinds of alerts .. & nbsp; cigdemilker 2012-02-28 00:00:38
08.05.2020 16:37 # 9
aspirinxlarge
I bought I will add 2 lira and 1 liter soon, but. & Nbsp; Should I be touring a bit. & Nbsp; Do you need to leave it running for about 15 minutes after adding it? & Nbsp;
08.05.2020 16:37 # 10
I guess it is enough to keep the vehicle speed between 2000-3000, I guess it will be enough whether you are idling or not. I think even enough .. easy to come ... & nbsp;
08.05.2020 16:37 # 11
http://www.uzmantv.com/aku-bakimi-nasil- made up & nbsp;
I forgot to say the water level will already tell in the video .. be on the plates but if there is a lot of space between them, 1 cm. It is enough to be on it .. more is also not good because .. it is difficult to transmit .. if there is not much share, if you make eye decision, it will be better to add water .. do not ful up to the mouth .. you can also check the holes of the plugs on the battery .. you can open it with a needle .. it also damages the battery .. & nbsp;
cigdemilker 2012-02-28 21:30:10
08.05.2020 16:37 # 12
aspirinxlarge
It wasn't idle, I went, I took two rounds. & Nbsp; 4000 to 5000 cycles. & Nbsp; I ran it for 20 minutes. & Nbsp; I came home and pressed it again. & Nbsp; but it will be determined in the morning. & nbsp; Meanwhile the brand Royal `miş & nbsp; It will be obvious how much we will be in the morning when it is strong. & nbsp; Meanwhile, he drank 1 liter of water. & Nbsp; I think it is low. & Nbsp;
08.05.2020 16:37 # 13
aspirinxlarge
Oh, I did not pay attention to the air vents, I went out at that time and I look at it in the morning anyway. & Nbsp; By the way, thanks for the comments. & Nbsp;
08.05.2020 16:37 # 14
djchaos
[QUOTE = aspirinxlarge] I will look at adding water, apparently we will hit it again in the morning, you are coming to the sun or snow. I go by bus now. :(
do not work by hitting your vehicle. New generation vehicles that can damage the brain in the future are not operated by hitting injection vehicles.
08.05.2020 16:37 # 15
I hope it does not cause any problems .. gradually the summer season is also approaching .. the cold is considered to be over .. & nbsp;
08.05.2020 16:37 # 16
aspirinxlarge
When it doesn't work it hurts my brain but:) & nbsp; it's not valuable to me either & nbsp; :))))))
08.05.2020 16:37 # 17
djchaos
vehicle damage to the brain and the brain not working means that the vehicle does not work, the exit price is between 800 and 1000 TL
08.05.2020 16:37 # 18
aspirinxlarge
[QUOTE = djchaos] car damage to the brain and brain not working means that the car does not work, the exit price is between 800 1000 tl [/ QUOTE]
In short, it is harm to the brain again & nbsp; :)
08.05.2020 16:37 # 19
djchaos
And if it's the salty one, if the car has a problem of not working due to the battery, have someone you know charge it from the car.
08.05.2020 16:37 # 20
Maybe you know if you do transfer but I still share it for my friends who don't know .. we have plus plus minus negative contacts. br>
first connect the plus pole head of the vehicle you are going to transfer with the positive battery. Then connect the minus pole of the vehicle whose battery is depleted. .. this prevents both glare from happening .. it saves you from approaching your transfer horse and approaching you ...
Page : / 2
