Battery-Airbag-Alternator help
08.05.2020 21:01 # 1
disocerydeli
Hello, have a good forum
My vehicle 307 2006 model vehicle 1. When I put it in gear, when I moved slowly, I saw fluctuation in the headlights, I checked the battery on it, it was cracked, I replaced it with a new one, 3-4 minutes after replacing, the airbag malfunction light started to flash, while the vehicle is going on, it flashes from time to time, 1 day passed, now it is completely on, despite the new battery. ripple continues.
the alternator appeared at 14.2-14.1
sonerkyl 2018-10-02 09:14:35
08.05.2020 21:01 # 2
Take the measurement of the teacher charging dynamo. Also check the fuses in the vehicle. Have the installed battery checked, maybe the production is wrong.
08.05.2020 21:01 # 3
I deleted one of them for opening two topics, hodja. It looks solid if you have an alternator control. And check the fuses, teacher.
08.05.2020 21:01 # 4
disocerydeli
I looked at the airbag fuse, it is already connected to the dashboard and the others are leaving
08.05.2020 21:01 # 5
Connect my teacher to a PC and see which airbag error he gave. There are two possible options, one is com2000 headlamp signal arm malfunction, airbag winding is disturbed, and the other is the disconnection of the cables leading to the armpit airbag.
