battery
08.05.2020 18:09 # 1
sefabasaran
Greetings to everyone 2004 307 1.6 xt sunrof my car has been running out of time battery was running out
i filled up last month, i was in trouble binod for 2 weeks i worked the car in 4 5 days
Today, the car did not buy a mars, the electricity went away, I hit it, whatever it worked then when it got hit, it didn't work again
Passenger airbag disabled warning and ice alert warning was coming. Later, when I turned off the ignition, the lights did not go out. Oil light airbag seat belt etc.
Also, the key was flashing and saying -0 in the place where the problem was km.
while I parked the car today, it started to sound out of the steering wheel, it got worse and it got better then WHAT ARE THE PROBLEMS FRIENDS
I WAIT FOR YOUR ANSWERS WITH FOUR EYES
08.05.2020 18:09 # 2
kursat3006
Flashing wrench service warning. It is usually set at 20000 or 10000, after leaving that km (206 is the same). But if there is no on-board computer, maybe it might be next to report a fault
08.05.2020 18:09 # 3
mev347
it may be caused by the battery and charger.
08.05.2020 18:09 # 4
sefabasaran
my name is sefa ankara, I am in the goatner, because my brother is in the military, I am interested in how long has there been problems in the vehicle, saying something like-key and flashing what does it require? my vehicle has a trip computer
08.05.2020 18:09 # 5
sefabasaran
today I disassembled the battery, I gave it to my charcoal, let's see if it will be improved tomorrow, but my fear warned the passenger that the airbag is not active, and the steering turn has gotten worse, the steering wheel has come, and then it has recovered. What should I do?
08.05.2020 18:09 # 6
hsnsnl
I wish my teacher did not give you a charge, if you buy a zero battery, you will do better .. it will always cause trouble for you ..
08.05.2020 18:09 # 7
barishrocker
the electricity of our vehicles is already sensitive. I think it is a nice battery. There is also the risk of staying on the road when I say run out of the battery .. after all, the batteries are good. I got a banner right now, they are good too;)
08.05.2020 18:09 # 8
Barut
ice alert
08.05.2020 18:09 # 9
barishrocker
If it is written on the chest in the middle screen, it is an icing warning. It happened to me last winter in my car. not a malfunction if he says it
08.05.2020 18:09 # 10
Hakank
This warning is given by warning under 3 degrees.
08.05.2020 18:09 # 11
barishrocker
What about the oil juice? we have to look at them ..
08.05.2020 18:09 # 12
sefabasaran
I thought I would handle the car until February, because we do not often ride the car, I said that I would buy zero batteries in February.
08.05.2020 18:09 # 13
sefabasaran
Greetings, friends, I have my car's battery charged. When I was wearing it, when I shake the battery, it sounds like a sound of water. I don't know much from the car.
Anyway I wandered around, turned the steering wheel and heard the sound when my foot was in clutch.
so what matters to me is there anybody who knows what's wrong with this problem? thanks
08.05.2020 18:09 # 14
ahmet_bjk
Steering iron passes slightly behind the accelerator pedal. If the mat is too far from the pedals, it may be stuck in that iron.
For the airbag light, you should check the on and off button of the passenger's airbag.
If the battery is dead there is nothing you can do with charging. You need to change it. Varta, Mutlu, Bosh brand batteries are of the same quality, whichever you find cheaper.
ahmet_bjk 2013-12-21 22:32:17
08.05.2020 18:09 # 15
sefabasaran
Thank you, I am glad that I became a member
My car is burning a bidet too much before the hike, it is 276 krş for the city. There is a focus on my father.
08.05.2020 18:09 # 16
Alicilik
Where are you in the HOcam goat?
It is not a good thing to discharge the battery. This way you cannot solve the event. On the contrary, you prolong the process in understanding the error.
Your battery value should be measured while the vehicle is running. According to him, the charge dynamo or battery problem can be considered.
The steering has become heavy and improved. If there is an airbag error and there is a problem in the horn, it may be tight in the com2000 winding. We need to look.
On fuel, ford diesel engines pejo production?
08.05.2020 18:09 # 17
sefabasaran
I'm in Keçiören pinarbasi ok today I will measure the battery value to you
vehicle focus 2004 comfort lpgli
08.05.2020 18:09 # 18
sefabasaran
friends also writes where is the history of the battery I wondered when it was taken platinum of my car's battery.
08.05.2020 18:09 # 19
sefabasaran
I charged the battery because I will not get into the car often, I removed the poles, it would be harmful to install the tool. Thank you.
08.05.2020 18:09 # 20
sefabasaran
I have oil, I brought your water to max
Page : / 2
