Battery
08.05.2020 18:25 # 1
yemre55
The warning light is on when the car is going on, the air conditioner does not work, then it does not work when it stops, but it works again when the battery is changed. He said there is no problem in the Charger, he said enough if you change the battery. He said there is a problem in the charge dynamo in the service. Can you help me friends ??
08.05.2020 18:25 # 2
ahmet_bjk
If the same situation happened after installing a different battery, there is a problem in the charging system, have your old battery measured without buying the battery.
